Rear Disks Wanted
Wanted or for sale
Locked
Driftmeister
Rear Disks Wanted
Post by Driftmeister »
hi guys
im looking for a rear brake disks for a S13
if you can drive it drift it
xtrail discs are a nice upgrade, but you will have to space the calipers out, or get yourself some nice r32/r33/z32 rear calipers. everything bolt on, 'cept for the brake lines iirc.
veecee wrote:xtrail discs are a nice upgrade, but you will have to space the calipers out, or get yourself some nice r32/r33/z32 rear calipers. everything bolt on, 'cept for the brake lines iirc.
vc i thought that the xtrail disk only worked for the front?
Speed breeder
0.7 Bar Boost
Post by Speed breeder »
cool...thanks vc...but what about the drum size...
is it the same or larger, and what needs to change in order to still keep most of the original handbrake components
nope - the xtrail rear disc is a perfect match for the 2pot caliper upgrade for the rear brakes. even the drum brake setup for the handbrake will work.
i dont know if xtrail front discs fit.
and its not totally bolt-on, you will have to drill 3 holes into the xtrail disc to fit your 4.114 bolt pattern.
Driftmeister
thanks VC u're the man
Locked
