hi guys
im looking for a rear brake disks for a S13
Rear Disks Wanted
Driftmeister
- 0.4 Bar Boost
Rear Disks Wanted
if you can drive it drift it
- Speed breeder
- 0.7 Bar Boost
nope - the xtrail rear disc is a perfect match for the 2pot caliper upgrade for the rear brakes. even the drum brake setup for the handbrake will work.
i dont know if xtrail front discs fit.
and its not totally bolt-on, you will have to drill 3 holes into the xtrail disc to fit your 4.114 bolt pattern.
Driftmeister
- 0.4 Bar Boost
