What wastegate??
What wastegate??
Like the topic states ,what would you guys suggest? I also cant find a x-mani thats bottom mount and can facilitate a waste gate, am i looking in the wrong place?
What turbo and engine?
rat wrote:What turbo and engine?
Ca18 T28/T3
38mm should do the job fine....
Draco wrote:38mm should do the job fine....
wont that boost abit high? i was thinking 44mm?
With a 44 the spring will be stiff, need more capacity to open it, but it could work I suppose....my opinion still.....38....because it is a 1800 motor....
Charl.....what does Dane say?
poizen
Real Name: Mical Mackay
Post by poizen »
i use a excell 36mm works great
Internall wastegate on stock turbo is 22mm, so anything above 25mm will do fine...
What is the conversion from bar to psi? Im looking at importing one , I've seen that you can get say a 46mm at deferent psi ratings?
