Fueling Fundi's
if you plan to keep your current engine then nistune BUT to find someone to tune it also keeps all your std sensors
dicktator cheap and anyone can tune it but little loads sites to tune compared to the nistune system
If you gonna run the same motor for a while go nistune.
For the record i can get you a walbro for R1200.
Andrew.200SX
Post by Andrew.200SX »
PFB said that he will setup the Nistune for me gratis .
Walbro pump - brand new R1200 ? If so I will give you a shout when I am ready. I supose it is better to get anyway , imaterial of the problem that I have at the moment.
IF NISSAN MOTORSPORT IS NISMO , DOES THAT MAKE HONDA MOTORSPORT HOMO ?!
Andrew.200SX
Hey guys , me again.
This car is really baffling me. When it is cold it runs semi ok , and when the heat guage rises it holds back.
This morning , I left the gym and a couple of trucks were holding me up, so I decided immaterial of the miss , boot it ! 3rd all the way up to 8000 , 4th 8000 no miss ! Check heat guage , it is still cold. 5 minutes later , boot it in 3rd , it starts holding back , look at the heat guage , it's halfway.
Why the hell would the car run fine occasionally. Surely if there is a fault it should be constant !
that sounds like with the extra fuel when it is cold it boosts fine but when hot its too lean
Andrew.200SX
What would be causing that ? I am also still convinced it is a fueling problem , but where do I start looking ?
It would be good if you can compare the afr between cold and warm. The fact that your car revs to 8000rpm worries me.
Andrew.200SX
Why would it worry you ? I have taken her up to 8500 when she wasn't cocking me around .
In otherwords , what is going to break ?
Charlvdw wrote:It would be good if you can compare the afr between cold and warm. The fact that your car revs to 8000rpm worries me.
ja the CA redline at about 7600 and the SR at 7200
do you have a piggyback on your std management?
Andrew.200SX wrote:Why would it worry you ? I have taken her up to 8500 when she wasn't cocking me around .
Breaking doesn't worry ,but the thing that does is the lack of a rev limiter before 8k.
Andrew.200SX
It is a stock S13 , except for the 76 mm freeflow and air filter. It was maintained by the Agents up until 150 000 and the guy I bought it from had it up until 158 000 , so I don't know if he did anything. Judging by the semi mutalated Sabre he was driving , anything is possible.
I'm not sure where the rev limiter should be but if its gone there could be some after market chip attached to the ecu which could stuff up your fueling.
Andrew.200SX
I can appreciate that , but the car was running perfectly up until about 3 weeks ago.
I think the best is going to be put it on a dyno and see if it is running lean or over fuelling or if it is losing spark.
what do you guys think ?
Sounds good.
