Fueling Fundi's
- Andrew.200SX
Fueling Fundi's
Hi , I need some assistance / advice.
'92 S13 CA18DET , standard, apart from 76 mm freeflow and aftermarket air filter.
The car was running fine , but has now started to feel like it is holding back when boosting. When cold , it's not so bad , more predominent when warm. At first I thought maybe it was fuel starvation , but after +- 5000 rpm , she pulls like a freight train. If I keep my foot flat from pull off , through the gears , she goes past the stagger in every low rev range and then runs. I am wondering if it isn't over-fuelling, and if so , why and where can I start fiddling ?
Thanks
Thanks
cursed_s13
- Andrew.200SX
- poizen
- Real Name: Mical Mackay
not to sure if it is fuel pump cos i have the same problem when it cold cold i put foot flat and it feels like it wanna go backwards but then it all comes right and i have a walbro feul pump so i susspect the fpr as im going to replace mine soonAndrew.200SX wrote:Thanks guys. I also suspect fuel. I have re-serviced the car , replacing plugs , filters , etc for just in case.
How will I check the fuel pressure ? Fuel pump ?
Get a gauge of sorts ?
- Andrew.200SX
- poizen
just what i have so i know it not fuel pump as it new still not sparks as i tested coils and got new plugs i susspect the fpr so im going to change to a after market one i have no boost leaks and all systems have been checked i have not got any error codes and all ohms are spot on so im left with fprAndrew.200SX wrote:It feels as if the car is being held back and then as the revs climb , she takes off like a rocket !
mayb someone else can direct us in a better direction
- Andrew.200SX
- Charlvdw
The car will make more power with higher pressure and I've seen this done and actually working but its not a good practice. Wanna increase your fuel pressure get a good pump and a decent adjustable FPR.Lindt wrote:stock regulator? check if it were bashed in to increase pressure, had the same problem on mine, some people think it'll make more power with higher pressure.
- Andrew.200SX
I am still trying to find the problem , without going through the expensive process of elimination. I have also noticed that she is running fine up to .5 bar boost and then between .5 and .8 is when the holding back is there. I have a feeling it is fuel related. The 1 injector is also still leaking. I got another injector from Faheem and bought all 4 new insulaters and o-rings from Nissan , but 2 or 3 days later the 1 injector starts to leak again.
If money wasn't an issue , I would start with new injectors , fuel pump and management. Which by the way brings up another question.... Diktator or Nistune ?
