HKS Fuel & R32 Management **SOLD**
Wanted or for sale
poizen
Real Name: Mical Mackay
Post by poizen »
Gary57 wrote:
same here with fmic and bigger turbo etc that not bad if you ask me
You hardly have a bigger turbo :wink: , so you are getting about 7km/l that is terrible. I get 8km/l and I make far more power, I think Trance101 is getting more than that and he drives like a hooligan :shock: . You guys should be getting 9-10km/l easy.
its still bigger and i do get the 9-10km but i like to sit on the gas alil besides you both have dicktator and wolf 3d we both got std so you cant really compare can you
Please explain. If anything you should get a better consumption...
poizen
Post by poizen »
i dont think so you have more tuning capabilities than std without nistune
after all that is why you went to wolf 3d is it not my nissan ecu still thinks im running std turbo standard smic and std boost when im not
Pinkfluffybunnys
Real Name: Ashley
Post by Pinkfluffybunnys »
Quote : ' The HKS PFC F-CON is a plug-in fuel management system designed to supplement and refine the OEM fuel curve to maintain a proper air/fuel mixture when increasing boost pressure in turbocharged applications. The PFC F-CON optimizes the factory injector pulse width signal by recalibrating information obtained by both the PFC F-CON absolute pressure sensor and the OEM engine control unit (ECU). Each unit is application specific and includes a preprogrammed ROM for a particular performance stage.'
1\4 Mile:
Because Race Car
poizen
Post by poizen »
Pinkfluffybunnys wrote:Quote : ' The HKS PFC F-CON is a plug-in fuel management system designed to supplement and refine the OEM fuel curve to maintain a proper air/fuel mixture when increasing boost pressure in turbocharged applications. The PFC F-CON optimizes the factory injector pulse width signal by recalibrating information obtained by both the PFC F-CON absolute pressure sensor and the OEM engine control unit (ECU). Each unit is application specific and includes a preprogrammed ROM for a particular performance stage.'
so in other words it cannot be used on a ca18det or retuned so it is only for the rb20det
Haha, ECU's dont think :lol: . It measures the amount of air flow and gives the correct fuel. I went Wolf because Nistune wasnt available then and I have more flexablity with Wolf than with Nistune.
poizen
Post by poizen »
you know what i mean my std ecu just is not set up for all the changes mayb that why i get bad fuel i dont know you the sx fundi why not tell us why even better tell us how to get the 9-10km range without the addition of any ecu
Has anyone EVER set the CO's on your car?? What plugs are running, what gaps?? What is your fuel pressure, how is the fuel filter?? There is tons to be checked...
PS: If you drive in boost like a doos all day then you will get a kak fuel consuption, I am talking about normal cruising...
poizen
Post by poizen »
Gary57 wrote:Has anyone EVER set the CO's on your car?? What plugs are running, what gaps?? What is your fuel pressure, how is the fuel filter?? There is tons to be checked...
co still to be set had them done wen got the car so still need to set and i know boosting my fuel doesnt last hahaha all the nice power but costs to much to use
Also who is setting them, Mr Govenders Curry den, tuning shop and sound specialists may not be the best people to do the job... :lol:
poizen
Post by poizen »
nope it my dads mate owns hyundi amanzimtoti workshop
As I said he may not be the best person to take it too... :roll:
What does he set the CO to??
poizen
Post by poizen »
well he did his trade working on 200sx and he setting it to the fsm
poizen
Post by poizen »
well he did his trade working on 200sx and he setting it to the fsm who should i take it to then
You were just saying that stock ECU doesnt work with your mods etc, but then why are you setting your CO according to the FSM?? Does he take you car out on the road or does he just do a static setting with the car idling??
I can do it for you, if you ask nicely... :lol:
Locked
