HKS Fuel & R32 Management **SOLD**
- FUEL PERFORMANCE
SOLD!
Last edited by FUEL PERFORMANCE on Fri Nov 13, 2009 10:47 am, edited 2 times in total.
FUEL PERFORMANCE SA-UK-EU
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
Does this replace the whole ECU like a Apexi Power FC, if yes, does it use the normal stock loom plugs?
The reason I am enquiring is need my aircon to work on the GTS-4 and I was told to get an Apexi PFC or a spliced std box to sort the aircon and some of the 4wd glitches with the dicktator management.
- FUEL PERFORMANCE
YesRiekert wrote:will it be able to run a SR20DET?
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
- FUEL PERFORMANCE
The way it was set up on my car when I bought the car was to run the Fueling only.Tobie wrote:Does this replace the whole ECU like a Apexi Power FC, if yes, does it use the normal stock loom plugs?
I'll check the Codes and so on and see what I can find out.
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
here's a link
http://www.hksusa.com/products/more.asp?id=748
if its not sold by the end of the month(finances allowing) I'll probably take it
- FUEL PERFORMANCE
Sure!Riekert wrote:here's a link
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
You hardly have a bigger turbosame here with fmic and bigger turbo etc that not bad if you ask me
