						Post
								by Charlvdw »
			Drillergy wrote:veecee wrote:remove the front section of propshaft and jack the front of the car up - that will get 95% of the old oil out!
once the prop is back in, fill it through the gearstick hole!
I think Ill send it to my Mech to do, this is outta my league
Or take it to VC.
- AGENT SX!
						Post
								by veecee »
			Charlvdw wrote:Drillergy wrote:veecee wrote:remove the front section of propshaft and jack the front of the car up - that will get 95% of the old oil out!
Or take it to VC.
no problem - i have a gap in my schedule sometime around april 2011.  shall i pencil you in?
- AGENT SX!
						Post
								by veecee »
Or take it to VC.
actually - this method only requires that you undo 4 bolts on the propshaft, and 4 bolts on the gearshift boot.  plus 1 circlip.  its no big deal!
- Real Name: Darryl
						Post
								by Drillergy »
			Ok Im gonna go look for these 4 bolts by the propshaft. The shifter thingy is easy
- AGENT SX!
						Post
								by veecee »
			they're gonna be tight bolts on that prop, dont crush your fingers when the nut cracks loose!!!
- Real Name: Darryl
						Post
								by Drillergy »
			veecee wrote:they're gonna be tight bolts on that prop, dont crush your fingers when the nut cracks loose!!!
I adjusted the clutch and it seems ok, clutch is high though. So Ill leave it for now.
Need to sort out the BOV, cos I feel theres a boost leak.
								Speed breeder
- 0.7 Bar Boost
						Post
								by Speed breeder »
			Or try the speed sensor on the other side...
						Post
								by Charlvdw »
			Speed breeder wrote:Or try the speed sensor on the other side...
Good thinking!
- AGENT SX!
						Post
								by veecee »
			Charlvdw wrote:Speed breeder wrote:Or try the speed sensor on the other side...
Good thinking!
you're right.  hell, that'll cut it down to 5 bolts to remove!  and it will make the job about 60% easier.
