i have the same maxima and the other import motor . i checked the rail and injectors they are side feeds. so your plan is to use the backie manifold and a topfeed injector and rail.the ones i have wont work .you will have to use a custom made rail?!?!?!
as for the local rb's they were rb30e and rb20e NO de or det.well start fitting the motor this weekend to get the engine mountings right.I ma looking for a 21R toyota box ,anyone in capetown got one?
that would work, try the tow truck companys. they lve the nissan v6 hardbodys,here they bu up parts and stock pile them,and wont sell you one even if they have more than one.coming back to my questio, thething atached to the front of the cam puly can it be used from another car, or is it 6cylinger /4 cylinder specific?
godzilla wrote:coming back to my questio, thething atached to the front of the cam puly can it be used from another car, or is it 6cylinger /4 cylinder specific?
Sorry man....what thing....cam pulley or crank pulley?
If it is the cas you are talking about it is not interchangeble between 4 and 6 cylinders....there is a "plate" inside with degrees that sends message back to computer to the alline timing and fuel....you can take the plate out and put it in the right cas....
so thats what its called,cas, i need one for the rb,i found some std injectors, and a std turbo, i need plug leeds and the cas , and a 21R box and bellhousing,got new water pump, and oil pump.
Ok so i have a CAS now and will get the correct 6cylinder plate when i buy my Dictator management .Now who knows if a CA18 gearbox is a direct fit on the RB engines?
godzilla wrote:Ok so i have a CAS now and will get the correct 6cylinder plate when i buy my Dictator management .Now who knows if a CA18 gearbox is a direct fit on the RB engines?
no but think you can get a bellhousing off a old skyline to fit it
problem is i dont have any of these ..YET... but the knowlege is key before i spend even if it is a small amount. Gonna have a look at aRB20 box over the weekendfor R2500 wich is cheap,and a direct fit.
