ok so i thought my Clutch fluid was being beamed up by Aliens... then i found out my Slave Cylinder has a sneaky leak.
Has anyone serviced their slave cylinder before? It looks like a straight forward operation, but where do i get the kit from... Midas? or is it going to be order from Nissan wait 2 weeks and pay 'Top Dollar" scenario??
Ja im guessing its the rubber seal attached to the back of the piston. But im a little worried about the actual piston and its contact area on the slave wall, as its not 100% smooth, it has a little patch of roughness.. but very little..?!
Charlvdw wrote:You can give me R60, i bought two from autozone paid R20.
I didn't know it was such a simple thing to sort out, so I got my mech to do it hence the R60. Oh ja. Don't forget to bleed the clutch, the nipple is under the car somewhere by the gbox.
DriftZ wrote:oh ja, that reminds me.. is there any special technique to bleeding both the master and slave cylinders.. ie one at a time or both simultanoulsy?
yeah same... also want to do that this weekend.
dont just pump the bottom, man! a good pump always includes the top too ?:?
the top one is there for a reason, and its in a super-aukward place, which is designed to piss you off!
if you only bleed the botoom, you will probably leave air up at the top of that long vertical pipe (air likes to go up!) and will leave that clutch squishy!
BTW - did gary take that horrible clutch loop out for you???
