Highboost
Posts: 106 Joined: Fri Mar 20, 2009 2:36 pm
Post
by Highboost » Tue Apr 21, 2009 11:07 am
Hey guys
How about some help, any ideas on what radiator to use with my 7mgte, in an s13???
Both water pipes are on the lefthand side of the motor ( thats standing in front of the car looking at the motor) I was thinking Golf MkII upside down????
Then I can run a cooler fan switch as well !!
Posts: 5723 Joined: Thu Aug 03, 2006 8:32 am
Post
by Draco » Tue Apr 21, 2009 1:52 pm
I used an STI radiator on my car, it fits straight into the sx's brackets, just needed to extend the bottom water pipe to the other side with the fan switch in.
Highboost
Post
by Highboost » Tue Apr 21, 2009 3:00 pm
Cool Thanks !!!
Will see if I can source one !
Pinkfluffybunnys
Posts: 1693 Joined: Thu May 08, 2008 1:21 pm
Real Name: Ashley
Post
by Pinkfluffybunnys » Tue Apr 21, 2009 3:06 pm
I would get an Uprated Radiator to cope with the heat of you new 6 cyc
1\4 Mile:
Because Race Car
Highboost
Post
by Highboost » Tue Apr 21, 2009 3:08 pm
Those nice big fat ali ones........
Post
by Draco » Tue Apr 21, 2009 3:11 pm
An aftermarket 3 core will be better, the STI is a 2 core, much better than the sx single core.
Highboost
Post
by Highboost » Fri Apr 24, 2009 1:56 pm
looks like an aftermarket 3 core will be the way to go. Contacted Mr Turbo for availabilty and price, any ideas of other places I could try ?
Post
by Draco » Fri Apr 24, 2009 2:20 pm
Import parts, turbo toys, turbo and nos....but in the end don't expect to pay what you would for a 2 core....
Highboost
Post
by Highboost » Fri Apr 24, 2009 2:25 pm
Rather be safe than sorry !
Posts: 7354 Joined: Wed Nov 08, 2006 3:49 pm
Post
by veecee » Fri Apr 24, 2009 2:25 pm
if you can weld aluminium then you can do nicely with a bmw 45mm core.
but the one i got, its a e36 radiator, is to wide. the rest of the dimensions are fine, but with the plastic overflow bottle incorporated into one of the side housings, its a bit too wide to fit the s13 chassis rails!
so i would remove the plastic side tanks, and weld in my own custom ones!
