I thought I would write a small injector cleaning guide for those people that would like to clean there 13 year old injectors.
*Note* Please be careful when removing the injectors from you fuel rail the will still be some fuel in the rail also be careful not to drop or damage the injector in anyway especially the pentil
Items Needed: 1 x AA 1.5v Battery, Carb Cleaner,Insulation Tape, Wire, Crimps, Container, two larger lengths of pipe and you dirty injectors
You will need t build the following items.
Battery:
Increasing size tube:
All the items:
Now you will need to remove the injectors internal filter
how to attach the hose to the injector
Start you cleaning *Remember* to reverse flush the injector as well
[/img]
