Wanted or for sale
SuperBaas
Posts: 203 Joined: Sat Feb 21, 2009 9:50 am
Post
by SuperBaas » Tue Mar 03, 2009 11:39 am
I have these stock T25 turbos. everything seems ok, remove from my car while they were working fine. 2k for both of them
Posts: 2078 Joined: Fri Sep 21, 2007 10:18 am
Post
by Drillergy » Thu Mar 05, 2009 10:21 am
Its a direct fit on a CA18DET?????
RB25SX
Posts: 1423 Joined: Tue May 06, 2008 4:38 pm
Post
by RB25SX » Thu Mar 05, 2009 11:21 am
SuperBaas wrote: I have these stock T25 turbos. everything seems ok, remove from my car while they were working fine. 2k for both of them
Do they have ceramic exh wheels ? What is exh housing size ?Did you upgrade ?
R32 GTR
SuperBaas
Post
by SuperBaas » Fri Mar 06, 2009 9:53 am
I am not sure if they will fit other nissans, its a rectangular 4 bolth flange. I did upgrade to gt28r turbos. There is plenty info on the zx turbos on the net. Please research and be sure it will work for you application.
Posts: 9505 Joined: Tue Jul 31, 2007 11:51 pm
Post
by Riekert » Fri Mar 06, 2009 1:04 pm
I think the stock turbos on the 300 had the same flange as the stock t25 on the CA.
Enzio wrote: Who needs ligths? When you're going sideways forward facing lights don't do anything but confuse squirrels and sheep next to the road...
300sx
0.8 Bar Boost
Posts: 882 Joined: Wed Apr 30, 2008 5:24 pm
Post
by 300sx » Fri Mar 06, 2009 9:42 pm
stock vg30dett turbo's are smaller than stock ca18det turbo's..
compressor side little smaller than ca18's, the turbine side is significantly smaller than ca18's.
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
gregT
Posts: 102 Joined: Tue Jan 16, 2007 8:53 am
Post
by gregT » Sat Mar 07, 2009 11:43 am
300sx wrote: stock vg30dett turbo's are smaller than stock ca18det turbo's..
but is it it a direct fit
300sx
0.8 Bar Boost
Post
by 300sx » Sat Mar 07, 2009 2:37 pm
should be.. same turbine family, but im not going to put my head on a block here, ive never tried it.
300zx fairlady 1991
gregT
Post
by gregT » Sun Mar 08, 2009 2:01 pm
so if one has to change the housings and turbines(propeller) to the stock ca18 it wont be a problem either.
RoyalBoy
Posts: 51 Joined: Thu Dec 18, 2008 11:46 pm
Post
by RoyalBoy » Tue Mar 31, 2009 11:42 am
What is the part numbers for these turbo's?
Do you possibly know the specs of the housings and wheel sizes?
