Need vlade's help...
Phinx
0.7 Bar Boost
Post by Phinx »
Ok I'm planning on installing my oil cooler soon.
Please Vlade I know you have done this how did you run the oil lines because they seem a bit to long on my car
And where did you put the oil cooler, And will it be possible to request pictures?
Thank you.
A.K.A - Wonderboy
1993 Nissan 200 SX
1989 Toyota Corrola
63kw - 117nm 1.3- N/A
Hennie Marais
Post by Hennie Marais »
I would say if the hoses are to long it'll be best to have them shortened at one of you local hydraulic shops. I'm fitting one too, my cooller is going where the original intercooler was, I'm using a FMIC.
Phinx
0.7 Bar Boost
Post by Phinx »
My Filter is where the stock cooler was, My FMIC is taking up to much space up front.
I hoping vlade installed it by drivers side wheel well
A.K.A - Wonderboy
1993 Nissan 200 SX
1989 Toyota Corrola
ChemCool
Post by ChemCool »
I think pics on oil cooler fitment on thread about Project D.
COOLER, FASTER, LIGHTER
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
As Freddy mentioned in my project D you'll c where I mounted my cooler.... from there I basically run the lines under the subframe but above my power-brace then to the cooler...
They are a little bit too long, but I made sure my pipes make nice and big turns and that there is lot's of place for flex, remember your pipes will also move as oil-pressure increases...
If you want to come have a look I'm in Centurion your more than welcome... I'll check if I have any pics of the lines
Remember after installing the cooler and before you start the car do the following...
* The Fittings in the adapter plate, put some thread tape on it! Turn them out of the aluminum adapter put thread tape on and fit them back.
* When fitting the lines to the cooler, put some multi-purpose grease on the adapter-fitting and the oil-cooler's fitting this will help with the initial seal
* Fill your oil-cooler up with oil to prevent the car from oil starvation.
Hairdresser MX5
Phinx
0.7 Bar Boost
Post by Phinx »
Thanks Vlade
really great advice
A.K.A - Wonderboy
1993 Nissan 200 SX
1989 Toyota Corrola
Why do all of you guys want to install oil coolers?? I stay in DBN and on a 40 degree day my oil temp is aroung the 100 degree mark, which is still good.
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
My car is purpose built for Track/Gymkhana/Drift and I have had some overheating problems before.
Hairdresser MX5
Dislex666
Post by Dislex666 »
exactly as vlade said - and if i wanna do a topend run at 6k rpm for 20 minutes, i don't want the oil to get on the hot side....
(and yes - i have done runs like that at 240+ for extended periods :D)
The Calibrator
Post by The Calibrator »
Plus bypassing the stock oil heater will drop your coolant temps by a few degrees.
qewrty
Post by qewrty »
Dislex666 wrote:exactly as vlade said - and if i wanna do a topend run at 6k rpm for 20 minutes, i don't want the oil to get on the hot side....
was that recently? i could do 230 quite easily in complete stock s14, but i only did it once for maybe 2 to 5 minutes chasing a very modded RXI car leaving from wesbank one night.
My current tire set is only rated to 230/240 so I eased off at around 235km/h.
I'm sure I'll be able to get up to that speed a lot faster now and so should you d666 :twisted:
I'm getting a very nicely sized oil cooler, 19 rows if I'm not mistaken. :)
Plus the obligatory nismo thermostat so I should be covered for now.
