Clutch shudddder
ljS14
Car: Evo
Real Name: Shane
Clutch shudddder
Post by ljS14 »
I have the ACT 6 puc clutch and pressure plate in my RB25 ,I have just got the car back and the car shudders when releasing the clutch,Not all the time but ever so often ,
Is this normal ???????????
I cant wait till monday to know as i am driving the car over the weekend to enjoy it ,Damn workshops who close over weekends :lol:
Anybody !!!!!!!!!!
1991 S13 200SX
1993 Z32 300ZX Convertable
Evo 8
does it have a sprung center or not?
ljS14
Car: Evo
Real Name: Shane
Post by ljS14 »
I don't know, got the clutch kit from Rezlo.
1991 S13 200SX
Evo 8
a sprung centered clutch will absorb most of the vibrations (shudders), and make it easier on the driver to smoothly engage the clutch.
a solid center will be far less forgiving and will transmit vibrations through the pedal, at least until the driver gets more used to the feel of the clutch. the solid centered clutch will also "bite" far more aggressively, making it feel more responsive and far "stronger" than a sprung centered clutch.
maybe you got a solid one?
ljS14
Car: Evo
Real Name: Shane
Post by ljS14 »
That makes sense ,When let it out quickly it is fine but as soon as i play with it in peak hour it bites me.
So this is normal ???
1991 S13 200SX
Evo 8
i would still check with the tuner (and maybe the supplier too) mabroo!
Guy
Post by Guy »
ljS14 wrote:That makes sense ,When let it out quickly it is fine but as soon as i play with it in peak hour it bites me.
Thats what puk type clutches do, you can't slip them, they're either on or off.
That is normal, mine did it aswell...
RAW
Post by RAW »
His is sprung,
When broken in right they smooth as silk on engaugement, very similar to stock clutch weight and feel, its just a reduced distance between in and out, most people would not even notice.
When you dont break it in right it will shudder slightly which is only noticable on pull away (makes it feel like local puc clutches)
If you whore the car when your supposed to be breaking it in you can plan on replacing the flywheel and presure plate within 10 000km's.
godzilla
clutch
Post by godzilla »
yep the shuder does happen when new , had a button clutch on my rb25t built buy ferobrake, and it was a night mare in trafic, was only supposed to be a trackday car but surcumstances made it a daily nightmare,but if you drive it in properly it will be good ,ant say it will be as smooth as a std clutch but then again i had a double diaphram.re- inforced for max bite so havin the best of bothworlds is a give and take most of the time it takes and takes hehehehehe
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
Normal...
you'll notice it will shudder more as the clutch gets hot, my Exedy did it as well... works perfect till you sit in traffic for a while...
Hairdresser MX5
