RudeBoy - 11.3sec 400m
- RudeBoy
- 0.5 Bar Boost
Update:
well, after being delayed by customs, finally received valves and springs.
head assmebled: +- 60hrs of work by hand + 24hrs on the cnc later the head is now ported and fitted with supertech S/S intake and inconel exhuast valves, Tomei valve springs and a pair of Tomei cam-shafts.
engine still on stand, waiting for branch to get back from powerkote.
will take some more pics over the weekend...
- RudeBoy
- 0.5 Bar Boost
RB25SX:
have a look at this site: http://www.turbobygarrett.com/turbobyga ... rgers.html
this is the one I'm using:
http://www.turbobygarrett.com/turbobyga ... 4568_2.htm
http://shop.rezlo.com/SA/index.php?act=viewCat&catId=4
- RudeBoy
- 0.5 Bar Boost
yea Gary, have a friend with a cnc that wrote a program to do a portion of the head work that would have been sh*t by hand, kinda like this:
http://www.theoldone.com/components/cyl ... s/skyline/
- RudeBoy
- 0.5 Bar Boost
more flow... (unshrouding the valves) - lower compression ratio at 8.6:1, that allows for more reliable high boost ( 2bar+) , should also allow more agressive timing, but i quess time will tell.
quote from "Endyn / theoldone" :
"Note that we've made some major changes to the factory's box-style combustion chamber. Our chamber design unshrouds the +.1mm oversize valves and our unique recessed quench pads completely eliminate the detonation-prone deep-stepped factory quench pads."
lotsa info available re this subject, but at the end of the day , you got to decide what you think will work for your application and how much of a risk you willing to take
