Ok what gives!!!???
Doctor G
0.7 Bar Boost
Ok what gives!!!???
Post by Doctor G »
Finally got around to fitting the 300zx brakes this week end. Only did the rears now as the std rears were finished anyways.
Now, bled the entire system but I'm getting a very spongy pedal that travels all the way to the bottom and the braking is very poor to say the least!!
What can be the problem? Did I maybe not bleed it properly? Maybe we can start with the bleeding sequence? I went with the furthest from the ABS pump to the nearest, so RR, RL, FR, FL.
Ero_sennin
Post by Ero_sennin »
did you bleed the abs unit too?
SONY Xplod inside
SR20DET Powered Red RS13
the bleeding sequence was right, but you also should bleed the abs unit!
and now for the kicker...
most people only install the fronts, and THEY say without the master cylinder the brake pedal travel and feel deteriorates slightly.
i'm guessing that with yours it must've got a lot worse?
nismo200sx's car isnt bad, but i reckon it (and probably yours) would benefit from the master cylinder upgrade too!
Doctor G
0.7 Bar Boost
Post by Doctor G »
Well think I found the problem. This may not seem obvious but when installing the calipers the damn bleeding nipples should ALWAYS be on top. I fitted them at the bottom to ensure I don't spill brake fluid on the newly painted calipers during the bleeding process.
This however allows air to get trapped in the top of the calipers which won't bleed out.
Ps: How do you bleed the ABS unit??
And who has a link to information about which direction the slots should face?
LOL - nana!
bleeding the brake system - its all in the manual!
dont slots rotate forwards??? outer edge first?
AR 200SX
Real Name: Armand
brakes
Post by AR 200SX »
you can face them either way.with them facing forward the pads wear faster but better brakes.just bleed the abs unit the same as a normal caliper.
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
from what I read back in the day was fitting Z32 rotors all round don't work too well with our standard master cylinder, but it will work... but breaking won't be up to spec...
Hairdresser MX5
n1smo200sx
Post by n1smo200sx »
Exactly the same thing happened to me but with the front calipers....was very dodgy with NO brakes ecept after 3 pumps of the pedal!!!Reconned the MC ,bought another MC and the "experts could still not tell me I fitted the calipers wrong way around!!Mine doesnt fell spongey and I lock the fronts still so I maybe think the intenet racers is pointing to pedal travel that increases a little bit .
