New Turbo
- Pinkfluffybunnys
- Real Name: Ashley
AI no man! now you guys confuse me again...
what do you think about the Mr Turbo Specs...?
T28/T3 Turbo Charger
Compressor Wheel T3 (46.5 - 60mm)
Compressor housing T3 A/R 42
Turbine wheel T28 (46.3mm-53mm)
A/R.49 Turbine housing.
And whats this Holset turbo's you're talking about??
- mario_200sx
Well If my calculations are correct, I need to run something similar to this...
http://www.turbobygarrett.com/turbobyg ... 7160_5.htm
which is close to the Mr turbo... well almost...
http://www.turbobygarrett.com/turbobyga ... 7160_9.htm
This might be closer...
GT2560R COMPRESSOR TURBINE
Turbo CHRA
707160-9 446179-65
Wh Dia Trim A/R Ind Exd
44.5mm 59.4mm 56 0.42
Wh Dia Trim A/R Type
53.8mm 62 0.64 Wastegated
Turbo CHRA
707160-9 446179-65
- Pinkfluffybunnys
- Real Name: Ashley
not arguing... just asking will that mr turbo be sufficient for a replacement?Pinkfluffybunnys wrote:I don’t get it what are we arguing about ?
Thanx man will do.RB25SX wrote:Dont think the Mr Turbo T28 has internal w.gate. You have to get Ext. w.gate and manifold to use it...... Might be wrong, just make sure.
- widowmaker
- Real Name: Walter
