New Turbo
New Turbo
How does this sound?
"SR20DET/CA18DET upgrade, street application. A/R 0.49
This turbo is designed for 1.6–2.0L engines and features a T25-size exhaust flange. This makes it ideal as an upgrade turbo for CA18-DET or SR20DET engines*. Rated at 280hp,A/C is 0.49. it is suitable for street performance applications. It features water cooling and a removable three-bolt exhaust flange.
Tested on a CA18 at *** Dyno, it produced 206kW at the wheels with 16psi of boost. The standard internal wastegate is designed to hold 11–12psi."
Its a GT28RS Ball Bearing turbo...
I think thats a Knock off turbo here are the spec's from Garret
GT2860RS-The Disco Potato COMPRESSOR TURBINE
Turbo CHRA
739548-1 446179-66
Wh Dia Trim A/R
Ind Exd
47.2mm 60.0mm 62 0.60
Wh Dia Trim A/R Type
53.8mm 76 0.86 Wastegated
TURBINE HOUSING OPTION
Part Number
430609-230
- - 0.64 Wastegated
Turbo CHRA
739548-5 446179-66
Wh Dia Trim A/R
Ind Exd
53.8mm 76 0.64 Wastegated
Part Number
430609-231
Oil & Water-cooled Bearing System
http://www.turbobygarrett.com/turbobyga ... 9548_1.htm
Turbo CHRA
739548-1 446179-66
Wh Dia Trim A/R
Ind Exd
Part Number
430609-230
- - 0.64 Wastegated
Turbo CHRA
739548-5 446179-66
Wh Dia Trim A/R
Ind Exd
Part Number
430609-231
yeah Its a knockoff BUT its a shit load cheaper that the original!Pinkfluffybunnys wrote:I think thats a Knock off turbo here are the spec's from Garret
- mario_200sx
Hey H, Pink fluff is just giving sum info, hehe he's Mr Info on the forum!HancoB wrote:jirre pink fluff is like those pains when you wanna take a really nice k@k. Always pops up when you least want it!
The man is down in the dumps man!
cut him some slack, that turbo will do for what he is going for, he doesn't need some super maguber of a fat turbo!
Riekert that will do fine for you!
Well its basically a T28 plus its brand new. I can get a reconed T28 from a NZ s14... but how long will that last me? And I don't think the power will be that different...veecee wrote: hey riekert
what about that T28 route yo?
go see mario's articles page for specs - its a decent upgrade, and you wont wait for boost! Wink
true true! thus Asking all the guys who run UPRATED turbo's or the guys who know's alot of stuffffsss.... WILL THIS WORK FOR MY CAR???HancoB wrote:yeah TMI is not a good thing! Experience is what counts...
Thus ask the people who have been through it all!
i've seen guys running t3/t4's on ca18's and it works for them.
and i've driven my ca18det without a turbo (it was installed but couldnt spin) so basically it was without a turbo at all!!!
they both worked. so what are your goals for the turbo? what do you expect to gain/lose from installing it?
