i have had 3 sx's and they have all done it, so i just thought it was "one of those things"300sx wrote:this sounds like a relay..my light stays on sometimes, have to turn off then on a few times then comes right?
ABS Unit
Will do man.300sx wrote:i feel your pain..keep us updated..
Speaking out of arse I do... but think we don't have one of those.... do we?
Ok... went home in my lunch hour.... started the car... grrrrrr noise. turned of, tapped little relays, started car... noise gone... so just holding thumbs that it's ok now...
is the light off???
cos the dash light could be one of a few things, the first being the ABS fuse. i cant believe noone has mentioned it. although if it is your ABS unit making a noise then i assume it has some power going to it.
the next from hanco would be the place to check. make sure that the plugs for the sensors are all connected correctly. you will find a sensor at each hub, and one on the diff. the hub sensor plugs are inside the engine bay, near the chassis rails - follow the wires to find them. the diff one - i cant remember!
then comes widows idea - although i'm not sure this will cause the dash light to stay on, but it might cause the unit to constantly open and close its valves. those are magnetic sensors and they pick up lost of metal filings and shavings - specially from the hub area!!! if they get too clogged they may send faulty readings to the abs ecu and that could make it repeatedly open and close valves.
there is also the supermegajuntion (or whatever the fukc its called). in the footwell of the drivers side is a massive square connector. it basically joins the ECU the ABS ECU and the wiring harnesses from the engine bay and the car. if there is a faulty connection there it can cause these problems - its happened to me before. make sure its well connected, and free of moisture!
then comes 300's suggestion. the ABS ECU - its located in the B-pillar on the drivers side. you would have to remove the plastic panels covering the seatbelt. the FSM has a list of the error codes and the way to test it.
man - seems complicated!
mine will in all likelihood be removed by the time i'm finished with sr20det swap.
pro's - its a big weight saving. i estimate that abs unit and its bracketry weigh in the region of 20kg's. nevermind the associated wiring and sensors. another pro is a neater engine bay.
cons - well not having ABS means you actually have to be properly awake when you drive. specially if you have upgraded the power!!! ABS is a very important safety feature on a car!!!
but i think i have to justify my case - i've had 3 front end accidents in my sx (yes i'm sure i am quite accident prone - fukc you murphy you C___!!!) none were that bad, in fact the last two were very light. anyway, in all three accidents when i applied brakes (hard!!!) the front wheels/tires just locked up, and i slid into things (1xpalisade fence, 1xditch, 1xpeugeot 307). so my ABS didnt help at all.
strange thing is my ABS is working and i know because i've tested it. in controlled conditions, like the street i live, and in a straight line, the ABS works fine. even on a skidpan, you can hear and feel it working, BUT when i needed it most - it didnt work.
so im seriously considering removing it!
but it helps, and all of those occasions that i mentioned, had my ABS worked as well as it did in my tests, then i am 100% sure that i wouldn't have hit those objects...
so thats 3 for 3, or 100% failure in my opinion!!! it never worked when i needed it, so its probably going!
- mario_200sx
- mario_200sx
