A T2.8/T3 Garrett journal bearing turbo
do exactory what G said!
go look in the classifieds section.
its no longer for sale, but dr g had one there. and there are photo's.
you stock MAF is a bottleneck in your system. it restricts the airflow when you start talking about 200hp or more!
but if you ditch the PP and go with a full management system you can run MAP instead of MAF, and then you will not be restricted at all.
i say aim for 180 instead of 150 on the wheels!
An adjustable fuel pressure regulator is one of the best things you can buy.
And their pretty cheap - like R400 for a good one.
1) This will immediatly be able to tell u if the stock fuel pump is still up to the job - or at least till where u can push it by checking for pressure drops as the motor revs/works hard at high rpms.
2) higher pressure at injectors = more fuel into engine that is required to make more power form more boost, etc. U get the idea. Obviously this also only works up to a point but is a simple fix rather than getting injectors that are too big/expensive....
3) Many standard SX fpr have been opened or tampered with to gain the advantages of an adjustable one - sometimes with the end result that the original one is stuffed.
Anyway - that's in my opinion always a good place to start.
I got a Nismo one for free... So will I be able to run it on my stock setup? will it make any diffs?Enzio wrote:An adjustable fuel pressure regulator is one of the best things you can buy.
sorry for the jack...
- mario_200sx
Your std fpr can be playin up. So fit it with a aftermarket one then you can check if your fuel pump is pumping at the right pressure. If not then you can adjust it.
Its more a safety precaution than anything else, like a boost guage.
It also helps for fine tunning your car.
Rolling Thunder..........
- mario_200sx
Anyway, back to the original point:
DocG's ideas sound pretty good. As for the T2.8/T3: it should be about the same sort of size as my TD04 (I think) - and like I said: it boosts from low down, not too much lag, pulls cleanly up to the redline and makes more than enough power.
For a daily drive it makes more sense than something like a T3/T4 which is way too big and will only start making power from 4500-5000 rpm probably (This was the case with one of the cars I test drove - granted that car's engine was fubar though...)
- 200SXSilviaSavage
Excellent guys
Sounds great... And Enzio, you're TD04 is probably a T25/T28... I saw a TD04H-15G that was this size... So if I do go for the T28/T3 I'm wondering if I'll maybe get too much lag with it? When exactly does your TD04 start spooling 0.1 bar?
@ VC...Thanx for the info bro... Although 180RWKW sounds a bit too much? Maybe I'm underestimating the CA's stock capabilities... I mean is anyone pushing over 150RWKW with stock internals reliably?
uh - at 0.1 bar???200SXSilviaSavage wrote:When exactly does your TD04 start spooling 0.1 bar?
LOL - kriekert - if you have it - fit it!!! how long have you been sitting on that without fitting it???
- rat
- Car: R32
- Real Name: Rat
i remember the guy fiting it for phobo what a mission he had, moding itRiekert wrote:I got a Nismo one for free... So will I be able to run it on my stock setup? will it make any diffs?Enzio wrote:An adjustable fuel pressure regulator is one of the best things you can buy.
so should just fit right in there now
rat wrote: i remember the guy fiting it for phobo what a mission he had, moding it
so you know about the nismo... hehe! ja, the fitment won't be the issue. it just the tuning....
