A T2.8/T3 Garrett journal bearing turbo
200SXSilviaSavage
Post by 200SXSilviaSavage »
Hi guys. I've been looking around for different kinds of turbos and right now I'm really looking at getting the Garrett T2.8/T3 from Mr. Turbo for around 3500... Anyone have this turbo or something similar? When will it start spooling? What's your views on this turbo for a daily driver? Sorry for all the Q's, just that this is gonna be my first new turbo and I wanna do it right and want this setup to last for a long while... Thanx
Sokar
1.0 Bar Boost
Post by Sokar »
Specs? compressor AR, Exhaust AR, trim wheels?
Captain Slow to the rescue!
200SXSilviaSavage
This is a quote off Mr. Turbo's website with all the specs of the turbo:
"T28/T3 Turbo Charger
Compressor Wheel T3 (46.5 - 60mm)
Compressor housing T3 A/R 42
Turbine wheel T28 (46.3mm-53mm)
A/R.49 Turbine housing."
Hope that helps...
Sokar
1.0 Bar Boost
Post by Sokar »
The compressor side seems ok, worried about the exhaust, AR is a little small, a good upgrade would be a .64 AR, I wonder if anyone else is running one of these.
Also remember if its a T3 exhaust housing the flange wont fit a SX manifold, you'll need a custom one.
Sokar isnt the T3/T4 flange the same as ours?? If you go with the 0.49AR turbine housing you will spool very early.
200SXSilviaSavage
Yeah thanx hey. This turbo is a T28 exhaust turbine and housing I think :? That's why it's a T28/T3... When will a .64 start spooling?
I heard people say about 4000rpm.
widowmaker
Real Name: Walter
Post by widowmaker »
sounds cheap - maybe it's a Gavvett ?
a while back a turbo was 10k new and now 3? doesnt sound right
mario_200sx
Post by mario_200sx »
T3/T4 flange is different than ours.
Oh ok.
mario_200sx
Its a pity! :cry:
200SXSilviaSavage
Woah! Okay guys I think 4000rpm is a bit high for a daily driver... When do you think the T28/T3 will start spooling? My standard turbo T25 started with 0.1 bar at 1950rpm...
200SXSilviaSavage
Seriously widow, this is a genuine Garrett turbo going for 3500... If you want a Garrett ball bearing, then you're looking at around the 10K range.
antman
Engine: VG
Real Name: Tony
Post by antman »
Hi 200sxsilviasavage, I am glad you are doing some ground work on a turbo upgrade as I also have been looking at this as well. Mysx is a daily drive and I currently have a T25 running at 1 bar which is not ideal and was thinking of a T28 or T3. I would also like to hear from those who have upgraded their turbos. has anyone upgraded to a T28 and what was the improvement. I personally think a T3/T4 would be too laggy for daily drives.
HancoB
Post by HancoB »
I'm Running a Disco Potato(GT28RS) and its great.
