So mine sprung a tiny leak which squirts water when the car is hot.
It's the one looking like a "U" against the firewall near the turbo. Anyone know where I can get this aftermarket? Nissan = R220
Heater hose
- Speed breeder
- 0.7 Bar Boost
Hey doc...mine burst completely in September last year, but not on the turbo side, there is also one on the intake side which is a bit more tricky to get to...it almost seems easier to remove the motor to get to this spot than it is to work in that tiny space to replace the pipe there.
Anyway what I did was use straight heater hose and connect it to a U aluminium piece of tube that luckily I had.
Basically what you need is new heater hose to replace the whole length - should be about R30 - R50 for 1m (Goodyear stuff at Midas/Autozone).
Also try plumbers for "U" type bends in copper or similar places... maybe you even have something at home.
My idea was just to ensure that the straight heater hose is not bent in any way.
Will take a pic tomorrow and post.
I don't think anything could go wrong with using the alluminium or even copper u flow as I have.
I think the only option is DIY or MacGuyver moves in order to save the $$$
I found and also
I found and also
huh???Speed breeder wrote:I found and also
i did the same thing on the U-shaped heater hose on a ca18 that i built for a mate last year! it was also on the intake side though. i also had to replace the same hose on my ca18 last year! i nearly pulled the motor out to do it too, but i managed in the end - although it took about 3 hours to replace that hose!
i still have some of the steel hose bends left after that build. they really work quite well.
you welcome to come get one!
- VoodooMaster
yo Doc. If you don't feel like making a Macgyver move then simply remove your pipe and go down to your local spares shop and try to match your pipe to what they have available. They might not have the exact same pipe but something similar in shape for some other car.
Is Going FAST SIDEWAYS.
- widowmaker
- Real Name: Walter
Thanks for the info.
I pulled the U-pipe that I thought was leaking this morning. It's on the turbo side of the motor and also a biatch to get to. Hand and arm scraped in a million little places (Guess that's how you would identify a fellow sx owner in a pub
After it was off I inspected it for leaks. F0koll!!! WTF.
So I proceed to the next heater hose. This is the long one with the many bends that reaches from the one side of the motor, through behind it, and then attaches on the intake side somewhere near the starter. After about an hour I got the biatch out. Check it for leaks, Nothing! Check the U pipe I removed first again and whallah
gaping little tiny hole.
Very pi$$ed off at this stage for removing a k@k pipe for nothing.
On to the spares shop and as you guess nothing in that shape. The U is not a prob but the one tip which bends in a different direction makes it akward to find.
So went back home, reainstalled the long pipe and simply connected it to where the U pipe originates instead of into the heater pipe in the firewall.
So effectively I took the heater out of the loop for now.
The copper U pipe sounds like a good idea to me. I think the fact that the pipe is so close to the exhaust manifold means it will always be suseptable to heating, cracking etc.
Still wanna see the pics pls.
- Speed breeder
- 0.7 Bar Boost
part number for everyone please???HancoB wrote:Mine burst too. I jacked the car up, took off the burst pipe, went to midas, matched a same size and bend pipe, fitted it and voila! Bobs your uncle!
Cost me R26.
thanks!
