Hi there!
So Saturday night I had some fun with the car after working on the turbo. when I got home I saw smoke coming from the turbo side and relised I never refitted the heatshield.
can anyone please tell me what this part of the harness does? everything in the car works fine, I disconected the powersteering and removed the aircon so I think its got something to do with the a/c and powersteering??
burnt harness on my 200sx please help!
neilbid_200sx
- Newbie
- Real Name: Neil
- Attachments
- sx3.jpg (823.07 KiB) Viewed 16339 times
- sx2.jpg (856.53 KiB) Viewed 16339 times
- sx1.jpg (798.77 KiB) Viewed 16339 times
Re: burnt harness on my 200sx please help!
fuel pump relay signal abs sensor aircon afm load resistor. are you running stock ecu?
neilbid_200sx
- Newbie
- Real Name: Neil
ok that sounds like good news for me I think. Running a spitronics engine management. Do you think I can just remove it completely from the car?
Thanks for the reply
you can yes but then your abs will not work unless you pull a new couple wires for the sensor
Yah just rip the abs. Then even less wires.
Sent from my MI 4W using Tapatalk
