Project ANARCHY
Re: Project ANARCHY
So this weekend got a few things done :D motor is in just need to do the odds and ends around the motor and we good to go
Re: Project ANARCHY
Nice Jason, good luck on the start up!!
widowmaker
Real Name: Walter
Re: Project ANARCHY
Post by widowmaker »
All hail J!!
Re: Project ANARCHY
Ok so first start up was successful motor started first swing once i decided to plug the ignitor in :facepalm: but could hear a miss and the car wasnt running 100% same as before the bearing knock and rebuild so checked the spark fueling ecu maf ect ect could not find what was causing the issue it seemed that cylinder number 4 was not firing properly after scratching my head for a week or so trying everything in the book i decided to do a compression test :shock:
So that was piston 4 lol so after seeing that i connected the compressor the the spark plug hole to find out where the leak was coming from turns out the exhaust valve was leaking quite badly :? engineering ftw :facepalm: so parked the car next morning friend and i pulled the head off only to find this
If you cant see it that middle valve is bent :D so both exhaust valvs were bent luckily i had spares lying around so we lapped new valves put the head on and after 12 hours of work fired the car up and she was running perfect [smilie=200sx_2guns.gif] Car has now done 800km and is a pleasure to drive replaced the rear bumper and had her detailed over the weekend and she is looking better than ever
Re: Project ANARCHY
Jussie you and Richard can polish n' ding stukkend huh!! :D
Cool stuff, glad it runs good. Well done!
Re: Project ANARCHY
Draco wrote:Jussie you and Richard can polish n' ding stukkend huh!! :D
lol no payed someone to polish it for me lol :lol: he took 9 hours to egt it to shine like that :shock:
Re: Project ANARCHY
Damn....he must be expensive, gotta pay me some good money to detail a car for 9 hours :)
Re: Project ANARCHY
Nice man.
Jokat
Real Name: Jacques Louwrens
Re: Project ANARCHY
Post by Jokat »
Congratz!
S13 200sx CA18DET
Re: Project ANARCHY
Looking good! but the boot! :D
Re: Project ANARCHY
lol yes will sort that out lol
widowmaker
Real Name: Walter
Re: Project ANARCHY
LOVE IT!
robldepo
Real Name: robert
Re: Project ANARCHY
Post by robldepo »
Dude your already so short you should be extending the hub lol.
Sent from my SM-G900H using Tapatalk
Re: Project ANARCHY
nice work Jason
Re: Project ANARCHY
Ok so long over due update will start with the white sx.
Aricon fixed
abs fixed
reverse lights fixed
interior light fixed
Have now had a total of 6 water leaks from pipes been so old :roll: but car is doing well have 8000km on the rebuilt motor and car is pulling like a train very happy with it as a daily
