BLOWN AGAIN...........please help
Hi guys
as i mentioned my mainfold gasket keeps blowing
On friday i picked the car up from the MAC, drove it below boost
for about 10kms then parked it , hopeing that, maybe the fire gum
will, maybe hold better or something
so yesterday i drove it for the first time after last friday, drove for about 15kms under boost, to heat it up abit
then i floored in 5th gear to 180kms, left the accelerator and droped to 120 accelerated alittle a there it was again BLOWN
this morning i started i and it sound like a truck, drove it to work
and now im in shit. ive wasted almost 2 grands and its still not working,
and im low on credit card funds
please advise
GARY IF you there i forgot my cell at home please pm your cell no.
please advise
Re: BLOWN AGAIN...........please help
Get yourself Aluminium sheet 1mm shoud do the trick and cut your own gasketsRBSX wrote:Hi guys
please advise
My brother's sx did the same .. atleast once wa week ! .. after we slaped on the aluminium it never had a problem ! .. running for about 2mounth now ! ..
www.MotorCade.co.za
I don't know how hard you drive or what power your car makes, but remember Aluminiun melting point is quite low.
Although it should not be a problem.
Just remember to retorque it quite often, as the Aluminium will squish out after a while.
http://www.MotorCade.co.za ... Click-click
http://www.InductionKits.co.za ... Click-click
http://www.Performance-Parts.co.za ... Click-click
www.MotorCade.co.za
Firegum is really terible, it don't even last on a high compression N/A motor, I have had endless trouble, I'm now also going to make my own gasket, as nothing off-the shelf is available, but luckily I don't drive it daily, likeonce every few months.Draco wrote:I don't know if you skimmed the manifold but if you didn't i'll start there, Freddie had s/s gaskets made and with the skimming and new gaskets it worked fine, I woulfd not rocomend fore gum, use normal sylecone....it works...
I really think S/S would be a better option
You just have to remember that the reason for having a gasket to compensate the different thermal characteristic of the head and the cast manifold. They will expand differently so therefore cant be a face fit. If you are using stainless go check to see how it expands in relation to the cast manifold and head.
I used those perferated stainless gasket and no problem. You just have to re-torque them a few times in the beginning.
Sorry about the 20 Questions....
But ...
What boost are you running?
Is it still the stock exhaust manifold and turbo?
Do you have a boost gauge?
Are you using stock nissan gaskets?
But ...
A.K.A - Wonderboy
1993 Nissan 200 SX
1989 Toyota Corrola
63kw - 117nm 1.3- N/A
1993 Nissan 200 SX
1989 Toyota Corrola
- johansx
- 0.4 Bar Boost
- Car: S14
Try to get the gaskets made from a couple of thin S/S sheets rivited together. Think mine comes from Midas. Try to replace the studs with new ones and always use NEW copper coted lock nuts. I also spend lots of $$$ and time taking off the S/S manifold until I tried the above. Never had problems with the cast manifold, but it is a good idea to check the mating surfaces.
www.MotorCade.co.za
Then use OEM, they should be better quality and ask Calibrator what sealer he uses, he should be using the best available with the stuff he builds.Gary57 wrote:Its stock... so 0.6Bar boost, stock turbo and manifold, non Nissan gaskets.
These thing are shit...Use those perferated stainless
Use nissan OEM and Copper Spray for the Head to Manifold gasket
Then also use a nissan gasket from the Manifold to turbo, Sealing with Fire-gun...
Thats what I use with-out an issue...
A.K.A - Wonderboy
1993 Nissan 200 SX
1989 Toyota Corrola
1993 Nissan 200 SX
1989 Toyota Corrola
