Hitting the 160rwkw mark - CA18DET
Re: Hitting the 160rwkw mark - CA18DET
Well Done!!! Did Marius do your IC and Kobus do the dyno?
MacNello
Real Name: Nello
Post by MacNello »
Thanks Drillergy :D
Yeah Marius did all my piping - amazing work ! and Kobus did the dyno he knows all the small tweaks to get the most out of any nissan engine ! Take my hat off to them both ! Doing really great work in JHB with a mind blowing garage of cars ! [smilie=200sx_2guns.gif]
I'm gonna be sending my sx there to complete the build. Can't wait!!!
Well done mate, that's a lot of power and the dyno graph looks smooth as well.
Have you got a standard ecu mac? And how much was the dump if you don't mind me asking
MacNello
Real Name: Nello
Post by MacNello »
Yeah standard ecu - doubt I can take it any further without major strains, will have to upgrade it. The BOV was included in my intercooler and piping package price but I seen them go between R550 and R750 its the SSQ Xcell one (with trumpet) - easy to clean and repair and goes for ever !
How much was the dyno
MacNello
Real Name: Nello
Post by MacNello »
It ranges hey - from a simple power run (cheaper) to actual adjustments and tweaks and modifications (depending on labour), Google Budler motorsport, give them a ring (ask to speak to Kobus)
i am very interested to what he did as the std ecu has no adjustments. Only the AFM has a slight adjustment used to set your co's
Enzio
Post by Enzio »
rat wrote:i am very interested to what he did as the std ecu has no adjustments. Only the AFM has a slight adjustment used to set your co's
^this
MacNello
Real Name: Nello
Post by MacNello »
Hahaha I know :shock: ! - He mainly played with the CAS, TPS MAF, and some vacuum lines...
Hope he didnt advance your CAS over the 15deg where it should be. All your maps on the stock ecu work from this value.
Good power overwise
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
nice power i need to get my car to go for a power run
get a power run on a other dyno too
maybe they cheated the computer
you can never be safe
She is the CA that IS
(O=O)/RS13\(O=O)
"EVERYDAY I'M FLUTTERING!"
