I just need some general opinions and suggestions on getting my SX to the ± 160rwkw mark. I know its not to crazy to get to but its a daily drive, I just like stepping it out on the streets and dropping the occasional DUB / ST.
It's a CA18DET (260 000km on the clock)
So far I've fitted :
- Cone Filter Induction
- 76mm St/Steel exhaust from the down pipe
- Installed a new T28 turbo with braided lines. (Only Boosting - 8psi = 0.55bar)
- Boost Gauge
- Turbo Timer
- Recently went in for a good service. (General service along with Diff oil and Gear box oil change - she's been regularly services every ± 5000 since she drove off the floor)
What I would still like to do:
- FMIC
- Oil Catch Tank (Tappet looks like its sweating a little, need it to breath)
- Walbro Fuel Pump
- Stage 1 ECU Chip (ebay)
- BOV (should it be a SSQ and do I mount it at the throttle side or intercooler(hot air) side ?)
- Injectors (will these need to be upgraded for this amount of Kw's ?)
- Finally a good dyno (what should the boost be upped to ? Don't wanna punish my motor)
Let me know what you think, looking forward to see the replies.
Keep it Sideways
MacNello
