Faulty window
Calvin
Real Name: Calvin
Faulty window
Post by Calvin »
Hi guys,
I have a problem with drivers side electric window. it goes down fine, but it doesnt go back up. I have to fiddle with the switch for a while, push it down, then up quickly to get it to go. Is it the switxh or something else thats faulty?
Grant222
Engine: 2JZ
Real Name: Grant Jones
Re: Faulty window
Post by Grant222 »
new relay box or dry joints need to be re solderd or clean contact points(in the relay box), had same problem, took it apart cleand the two switch contact points with 800 sandpaper and working 100%.
Calvin
Real Name: Calvin
Re: Faulty window
Post by Calvin »
Thanks will give it a try, which relay box is it in?
Re: Faulty window
in the door there is a black box
Calvin
Real Name: Calvin
Re: Faulty window
Post by Calvin »
Ok cool. gona take it apart now and check it out. Thanks
Calvin
Real Name: Calvin
Re: Faulty window
Post by Calvin »
Stripped it. The relay box doesnt click on the up movement. eventually it does and the window goes up. any ideas how much the new relay is?
Grant222
Engine: 2JZ
Re: Faulty window
Post by Grant222 »
Dont buy a new one, open that one and check it first
Calvin
Real Name: Calvin
Re: Faulty window
Post by Calvin »
How do u open it. It looks like a sealed unit?
Re: Faulty window
Its your window switch that is making kak strip that and use sand paper to clean the contacts
Calvin
Real Name: Calvin
Re: Faulty window
Post by Calvin »
Well i opened both up and cleaned them out with sandpaper and an electronic cleaner spray, still no joy. Going to have to look at replacing them. I will test a second hand one first and see which is faulty
Grant222
Engine: 2JZ
Re: Faulty window
Post by Grant222 »
Try a new(second hand) relay, i dont think its the switch
NIZAN-R
Real Name: Renier
Re: Faulty window
Post by NIZAN-R »
new box lol they are gold if you find them
like Grant said solder all joints even if they look good solder them
the capacitors legs break loose and you dont always see it
She is the CA that IS
(O=O)/RS13\(O=O)
"EVERYDAY I'M FLUTTERING!"
NIZAN-R
Real Name: Renier
Re: Faulty window
Post by NIZAN-R »
(O=O)/RS13\(O=O)
Re: Faulty window
Are both sides not working or just the one
Calvin
Real Name: Calvin
Re: Faulty window
Post by Calvin »
Its just the drivers side door that doesnt work. The passenger window works perfectly
