Faulty window
- Real Name: Calvin
Faulty window
Hi guys,
I have a problem with drivers side electric window. it goes down fine, but it doesnt go back up. I have to fiddle with the switch for a while, push it down, then up quickly to get it to go. Is it the switxh or something else thats faulty?
- 0.9 Bar Boost
- Engine: 2JZ
- Real Name: Grant Jones
Re: Faulty window
new relay box or dry joints need to be re solderd or clean contact points(in the relay box), had same problem, took it apart cleand the two switch contact points with 800 sandpaper and working 100%.
- Real Name: Calvin
Re: Faulty window
Thanks will give it a try, which relay box is it in?
- Real Name: Calvin
Re: Faulty window
Ok cool. gona take it apart now and check it out. Thanks
- Real Name: Calvin
Re: Faulty window
Stripped it. The relay box doesnt click on the up movement. eventually it does and the window goes up. any ideas how much the new relay is?
- Real Name: Calvin
Re: Faulty window
How do u open it. It looks like a sealed unit?
Re: Faulty window
Its your window switch that is making kak strip that and use sand paper to clean the contacts
- Real Name: Calvin
Re: Faulty window
Well i opened both up and cleaned them out with sandpaper and an electronic cleaner spray, still no joy. Going to have to look at replacing them. I will test a second hand one first and see which is faulty
- Real Name: Renier
Re: Faulty window
new box lol they are gold if you find them
like Grant said solder all joints even if they look good solder them
the capacitors legs break loose and you dont always see it
She is the CA that IS
(O=O)/RS13\(O=O)
"EVERYDAY I'M FLUTTERING!"
- Real Name: Renier
Re: Faulty window
if you want to buy one
http://www.ebay.com.au/itm/89-94-Nissan ... 3cc2bed332
http://www.ebay.com.au/itm/nissan-s13-s ... 3f1528f4c4
(O=O)/RS13\(O=O)
Re: Faulty window
Are both sides not working or just the one
- Real Name: Calvin
Re: Faulty window
Its just the drivers side door that doesnt work. The passenger window works perfectly
