D1 spec oil catch tank fitting (CA18DET)
MacNello
Real Name: Nello
Post by MacNello »
Hi Guys
I need a little help, I've done a lot of research on this topic and have found a whole bunch of answers that left me worse off than when I started :facepalm:
My Tappet cover is sweating the black sludge of death and so is some of my boost pipes going into the intercooler. So before I fit my FMIC I'm fitting and oil catch tank so the engine has a closed looped breathing cycle to prevent/decrease sludge build up.
This is the catch tank
This is my layout
This is how I had it fitted according to a diagram I found
http://www.topscreative.co.za/nello/how_I_had_it.jpg
Do I need to block of the PCV ?
http://www.topscreative.co.za/nello/pcv.jpg
My Exhaust outlet is a "L" shape, one goes the the air intake (behind AFM)
http://www.topscreative.co.za/nello/L-shape.jpg
I just want to set this thing up so the engine can breath properly and the sludge is not going into any of my pipes but to the tank instead...
Please feel free to post photos of your setup or MS Paint/Photoshop over my engine diagram !
[smilie=200sx_200sx.gif]
NIZAN-R
Real Name: Renier
Re: D1 spec oil catch tank fitting (CA18DET)
Post by NIZAN-R »
Delete blue pipe conect your hose pipe on the spot on cam cover
She is the CA that IS
(O=O)/RS13\(O=O)
"EVERYDAY I'M FLUTTERING!"
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
conect where filter is
ps that hose is to thin
(O=O)/RS13\(O=O)
MacNello
Real Name: Nello
Post by MacNello »
Thanks for the reply
Hahahah "Hose pipe" I know it's dodge will be replacing the stock supplied pipe with some new one's mid week.
So I just leave it as is, only remove the blue pipe ? plug it off at the induction and plug the catch tank pipe to where the blue on was on the exhaust outlet... [smilie=200sx_2guns.gif]
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
that will be the way to go
i moved the pink pipe to where blue one was
and fitted filter on top
(O=O)/RS13\(O=O)
MacNello
Real Name: Nello
Post by MacNello »
Just a follow up
Its all connected now [smilie=200sx_2guns.gif] - Pluged the pipe to the turbo intake. Thanks a mill Nizan-R [smilie=200sx_200sx.gif]
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
(O=O)/RS13\(O=O)
White Fang
Real Name: Qubitt (Qbit)
Post by White Fang »
Shit !
Well done, you both lost me in the beginning , But now seeing the end result , i am up to date ,
What is the catch tank for ? i know its oil , but why ?
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
when motor gets old rings wear out causing blow by
that pushes oil out of breather
stock setup motor burns the oil as it is sucked back into the intake
(O=O)/RS13\(O=O)
White Fang
Mmmm
Maybe i must do that to the SX .....
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
But with that setup there is still a breather attached to the intake manifold throwing oil into the intake in anycase? When i connected a catch tank to my friends Almera Turbo conversion i made both the breathers off the tappet cover go straight into the oil catch tank, and the nipples on the intake i blocked off completely, so the fumes and oil only go into the catch tank so the intake gets nice clean air, but his catch tank was a big DICE one with a big element filter etc, but i would like to do the same to my SX but to me it makes little sence if theres still a pipe leading to the intake? Perhaps i have the concept wrong but thats how i understand it.
nissan sss
Real Name: Hannes
Post by nissan sss »
think i must also do this my boost pipes has got a lot of oil inside the spraying out the dump valve
Real Name: ????
Post by Adrian »
there is no breather pipe on the intake..
it comes from your block up to the cam covers but yea rebuild your motors and you wont need this...
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
+1 but hi boost will still blow by oil but not much
the hose that goes to the intake has Pcv valve so will only suck oil when of boost and on ideling
(O=O)/RS13\(O=O)
