300zx turbo OEM pistons
antman
Engine: VG
Real Name: Tony
Post by antman »
I have 4 stock twin turbo pistons (std 86.5mm) and rods for sale for the SR boys wanting to convert. R500 for the lot.
West Rand JHB
082 8766837
300sx
0.8 Bar Boost
Re: 300zx turbo OEM pistons
Post by 300sx »
might wanna try the mazda forums too, i hear they love these for the FE engine..
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
Hey 300sx what power diffrence will it make to the s14 sr slant top will it change compression ratio's etc.
aep886
Real Name: Davey
Post by aep886 »
it will bump up the capacity to around 2050cc... compression pretty much the same... but the shit is you need to bore your block!
current vehicles...
1979 Corolla SR5
1996 S14 200sx
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post by Grobblere »
I would of taken them, but i need 6! :D
phoenix s14
Real Name: Mark Appelgryn
Post by phoenix s14 »
Will raise compression slightly... dish is apparently less than SR and then the bigger size will raise compression. Well thats what my research told me before...
aep886
Real Name: Davey
Post by aep886 »
bigger bore = less compression ^^
compression is very easy to fix just replace different thickness HG it sorted!
current vehicles...
1979 Corolla SR5
1996 S14 200sx
phoenix s14
aep886 wrote:bigger bore = less compression ^^
That is inaccurate. thicker head gasket yes will drop but bigger piston squishing more volume of mix into the same (or very close to same depending if you have done some mods) combustion chamber = higher pressure and hence higher compression.
Sorry did not mean to thread jack... free bump. :D
aep886
Real Name: Davey
Post by aep886 »
oh well... have you see the Vtec pistons? there is no dish and it actually have a raised piston center... (i can be wrong here, but i have build a few engines and from firends car that is what i notice) i was talking about thinner HG^^ to raise not to drop^^
current vehicles...
1979 Corolla SR5
1996 S14 200sx
ok so more to the point what will you need to do to get these in the SR? and will they work with the SR Rods?
ok nvm about the rods I misread see i can get rods with
