Blueish smoke!
Blueish smoke!
Hi guys, first day on the forum, be nice. My s13 (very cool car) started smoking up at low revs when im off the power(decelarating). I did by accident fill up a lil too much oil which seem to have started the smoke issue, however, the oil level is almost normal now but still smokes up. Any advise on how to fix this guys... also, has a sorta flat spot between 2 -3k rpm. Any help will be much appritiated.
- Charlvdw
Dont think to much oil can damage any seals that will cause smoking, thats the symptoms of turbo on its way out.
As for the 2-3k might be the knock sensor situated on the RH side(Driver side) of the motor in front of the starter behind the brace/bracket supporting the intake mani. My money is on fuel pump tho.
- Charlvdw
Best you can do for a fuel pump would be a Wallbro , you can get them from R1k to R1,5 depending on who you buy from.
I believe Pegasus still has one he want's to sell.
Turbo , well this is where the fun starts, best option would be something like a GT2860 which would probably set you back in the R10k(new) reagent.
Alternatively you can go for a WR280 from MR Turbo or Stallion turbo's ,they go for round R4k.
- Real Name: Willem
blueish smoke.
it could also be that when you overfilled with oil, you now have some oil residue in the exhaust and that is whats coming out.
just basics
just basics
- P3g4sus
- Club Drifter
- Car: Supra
- Engine: 2JZ
- Real Name: B.G. Smit
Thanx for the bump Charl, But sold it already!Charlvdw wrote: I believe Pegasus still has one he want's to sell.
Yep, Very good turbo's that!Charlvdw wrote:WR280 from MR Turbo or Stallion turbo's ,they go for round R4k.
Traction is over rated.
