SR20DET Oil pump to Strainer gasket
Post by Ero_sennin »
Hi, Looking for the gasket between the oil pump and oil strainer, S14/S15 gasket asap!
Re: SR20DET Oil pump to Strainer gasket
Use some good RTV loctite gret sealer gasket maker, no need for a gasket, you're talking about the oil pick up gasket? sealer will be fine, you can use that sealant on a sump or gearbox alone and ive never seen a leak yet.
Use some good RTV loctite grey sealer gasket maker, no need for a gasket, you're talking about the oil pick up gasket? sealer will be fine, you can use that sealant on a sump or gearbox alone and ive never seen a leak yet.
