It is AR80, and it is only oil cooled, there is no water cooling channels atall, also i wanted to ask, there is very little play on the shaft left and right, however inwards and outwards there is some play and if you push the exhaust turbine inwards and try and turn the shaft there is a bit of resistance but if you push in the intake turbine and turn it then its nice and free, so im a bit sceptical anyways but what are you guys thoughts?
Thanks
