On light throttle freeway cruising its about 18:1 which is a bit on the lean side but the car is not jerking or anything so thats not to bad but EGT is about 670degrees which is good.
When I accelerate slowly and boost is about 0Kpa (no vacuum no boost) its about 15.5:1 which is too lean, good for fuel consuption but not for torque.
If I floor it AFR would drop to about about 12.2-13.0 which is again to lean, althought that was with the water/meth on. I noticed sometimes that its even as low as 10:1 at about 0.6Bar boost but then leans out as boost goes up, it just makes no sence. EGT reaches about 850-880degrees on a 10 or so second run.
Also when cruising, straight after I tap off it richens up to about 11:1 and then leans out. Why does it richen up straight after I tap off when I have set the fuel cut active??
I did all of this using the datalogger which is a real cool function but shows your everything little problem in the map
Now I have found the problems what should I do?? Should I go to the map and adjust it accordingly or do a few more runs and see if there is a pattern and then adjust it??
Also this datalogger is very very sensitive should I concider ever little blipper in it or just the big ones?? It is reading at something like 75 samples/second
