Manifold and turbo conversion
- gregT
Hi, i was wondering if swopping my existing manifold and turbo for a new tubular cast iron manifold and a T3/T4 would be a good idea. i phoned someone from a company and he suggested it. i asked about management and he sadi that stock management will run fine. im not looking for alot more extra power but am just thinking for the long run. would it be advisable.
thanks
thanks
- gregT
it is a daily drive and its an s13 with ca18det. thats why i was a bit confused with the fact that no management system would be required. see the problem i have is that my turbo keeps blowing, and what i wanted to do is to send it in so that it wouldnt stand around in the garden, because i need to drive it to work etc. so i thought if i send it in it will be done and if i have any problems afterwards ill just send it in. ive removed my turo and manifold today(the reason why is because it made a siren type of sound after 3000) the shaft does have a bit of play which i think is a bit to much.
I'm running a Tubular manifold and Custom Turbo with custom down-pipe @ 0.5 bar on my Car everyday with the stock management system with a slight bit of over fueling seen in the plugs and under heavy acceleration.
What boost do you plan to run? Whats the flow rate on this T3/T4?
I honestly don't see any issue, I know a few guys on Nico club running Gt28rs on the stock management and you could chip the ECU if needrd at a later stage with a chip from DR drift or somthing
Just my 10 cent ZIM
Just my 10 cent ZIM
- gregT
thanks that 10 cent zim was worth more than the real zim cent. ill boost at 0.5-0.7 bar. not sure what flow rate it is. i was just thinking of doin it so that if i ever needed or wanted to up the power i have that done already. how much did yours all cost. cause i was thinking of about 8000.
thanks again
thanks again
Opinions are like assholes everybody has one and they are all worth what you pay for them.
Use them dont use them its no skin off my nose.
![200SX_dots [smilie=200sx_dots.gif]](./images/smilies/200SX_dots.gif)
Anyway
All in all it was :
R2000 for the Manifold
R1200 for the Down-pipe
R3000 for the Turbo - I got it from a good friend
R 800 for the gaskets and
R 100 to get the exhaust flange re-welded
So around R6100.
The manifold and turbo made a huge difference on my car . It made my car pull like a train in my eyes and I haven't blown a gasket yet touch wood .There is a Post with my Dyno sheet on the forum
Also gregT your welcome to come get a drive in my car and I will show you what I have done on the stock management ...
![200SX_cool2 [smilie=200sx_cool2.gif]](./images/smilies/200SX_cool2.gif)
- Vlade
- * - Club Pimp - *
- Real Name: Barend
To me I think your trying to solve the problem the wrong way... I think its a lubrication / oiling problem, wrong oil or not enough oil... since you keep blowing turbo's... That or you turbo is over spinning for some reason boost leak / faulty actuator...gregT wrote: see the problem i have is that my turbo keeps blowing, and what i wanted to do is to send it in so that it wouldn't stand around in the garden, because i need to drive it to work etc
The stock manifold won't cause something like this... Tubular manifolds on the one hand aint a good idea either since they have the tendency to crack if used wrong...
If you havn't nailed the cause don't guess it, take it to a tuner like Calibrator let him find the cause and fix it for you. My 20 Zim dolla advice
Vlade Nailed it on the headTo me I think your trying to solve the problem the wrong way... I think its a lubrication / oiling problem, wrong oil or not enough oil... since you keep blowing turbo's... That or you turbo is over spinning for some reason boost leak / faulty actuator...
Are you reconing the turbo? The guys at a Turbo recon place should be able to tell you why the unit failed.
P.s If it a Boost leak make a boost leak tester...
I have one : URL: http://www.vfaq.com/mods/ICtester.html
My 5 cents Zim
- gregT
all these zim dollars are adding up here. maybe ill be rich one day, or not. thanks, i did check to see whether or not oil is passing through the turbo after the second time. the reason i think the first turbo blew was because it was from an import engine and from being freighted it was lying in water and over the time it rusted and collected sediment etc. the second time im not sure about so i want to find out what the problem is. but on the other jhand i still want to get the manifold and new turbo. the manifold is made from cast iron from the one quote that i got. maybe it would be best just to send it in and find out the problem, at least it will be done.
ya phinx that would be nice to feel your car(but not in that way). ill let you know when im in town, and will make a plan.
also how would i know if the actuator is gone?
thanks
thanks
If the actuator is gone and jammed closed or not opening correctly It would show as boost spikes and over boosting if sticky.
If it was stuck partially open it would struggle to reach the set boost pressures and Maybe over spin and surge the turbo. Normal from what I have read the compressor wheel will get damaged or might disintegrate under these conditions .
Hennie is the man to talk to about these things, The guy has a mountain of knowledge his forgotten stuff I'm still learning...
when i first got a 200sx i did a lot of reading regarding the ca18det, and the sr20det!!!gregT wrote: i did check to see whether or not oil is passing through the turbo after the second time.
i found that with the ca18det, there is a nasty tendency for the oil feed pipe to kink near the inlet to the turbo, where the hard pipe takes a nice little 90 degree bend. when i checked my car, it had the same issue, and it was the first mod i did on my car (in fact - i've left that off my garage details!!! oops)
this often happens when people remove, and put back, their turbo's!!!
so your turbo gets starved of oil, and it doesnt take long before it blows!
check out that oil feed line, in fact i would recommend replacing it with steel braided hose anyway!!!
and who is quoting you for a CAST IRON manifold, what does it look like, and what does it cost, and who made it!???!
