Wanted -Fuel pressure regulator solenoid valve
- S13- S14 Conversion
I'm in need of a solenoid valve for the S13. Mine just suddenly stopped working. If anybody got one spare, please let me know.
Thanks.
Thanks.
200SX S13 converted with SR20DET engine and bigger front intercooler.
0.4bar boost & 140Kw
- Daniel
- Real Name: Daniël
OH
sorry i some how completely missed the thread title
just bypass it, its a hot start solinoid to aid in starting the car when its hot. Mines been bypassed for 2 years and iv never had a problem starting it.
Just connect a pipe from the plenum straight to the FPR, remembering to block or completly remove the other pipes connected to the solinoid
It's the thing just below the power converter. It's a round cylinder type thing with two vacuum pipe connectors on top and one connector on the side.Gary57 wrote:Post a pic, if its what I am thinking of, I dont use it so you can take it.
daniel is right - although i do have an adjustable FPR, i removed mine and replace it with a straight line to the FPR.S13- S14 Conversion wrote:It's the thing just below the power converter. It's a round cylinder type thing with two vacuum pipe connectors on top and one connector on the side.Gary57 wrote:Post a pic, if its what I am thinking of, I dont use it so you can take it.
so i have one lying around.
only issue would be that you no longer have a CA18det, and does the SR20det react in the same way if you remove this part???
have you checked the manual.
When I bypassed mine , My car ran like Crap...
I know have a Nismo FPR and it still runs like crap disconnected especially with cold starts.
So I put it back in .
One Question why remove it? The ECU needs it for cold Idle control
But I don't think the SR works the same way
