Ca18det computer box
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post by Grobblere »
Hi Guys
Seems like my stock box is ffffdup. :facepalm: . Does anyone around pta have a spare? I am located in Centurion.
(If i cant get one im gonna settle for a aftermarket jobby)
Regards
Eugene
Re: Ca18det computer box
Hi Grobblere, i have a ECU for you, it works perfectly except it drains battery over time, Whats wrong with yours? The only issue i had with this one is the ECCS relay stayed on and would drain my battery over a span of a couple days, You can have it for R300 and shipping can be arranged, let me know. Thanks
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post by Grobblere »
Hi Coljin
Thanks for the reply, to be honest im looking for something closer otherwise im going to go get a stand alone, my box seems to be damaged due to the incorrect plugs on the incorrect sensors by the previous owners. The water fluid temp plug was put on the VAC an visa versa. Only checked it out when i pulled my motor last week and noted that the wiring has also been cut.
Ok cool, no worrys, goodluck finding another one in your area. Cheers
ClasS13st
Real Name: Eugene Heynike
Post by ClasS13st »
i've got one bud. i'm in randburg.
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post by Grobblere »
Thx but i already have a dictatorrrrr
