Just a reminder of what Custom Motorsport has to offer. Some new products added.
For more info please go to the traders section.....
Coilover Kit Details
Features of Custom Motorsport Coilover Kits
Made from high quality material for increased hardness
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Adjustable upper camber mounts provide better adjustment
Professional installation recommended
All parts and after sales service is done by Custom Motorsport
Price between R5500 - R7500 per set (Groups buys can be done)
EK:
EF:
800hp - 1000hp forged rods (ARP Rod bolts included)
800hp - 1000hp forged cranks (stock or stroked)
Cam gears
Underdrive pulleys
Suspension Arms
Intercooler kits (whole kit or just pipping)
Camber Plates
Loads of different sizes avail!
60mm, 75mm and 100mm neck sizes
Prices between R350 - R660
- Designed to be used wet or dry making it the most advanced filter on the market
- Strong and lightweight galvanised steel mesh
- Deep pleating with 3D weaving technology
- Urethane moulded base ensures superior contact with body providing strength and reliability, making it suitable for all high revving turbo and performance engines
- No bleed infringement resulting in unrestricted airflow and maximum filtration and performance
- Lifetime warranty
Gauges: Both Black and White faces avail
Saturn Range: R420 - R650
Sapphire Range: R950 - R1160
Plain Black
or
5 Speed H pattern
R300-00
Plain Black 5 Speed H Pattern
R300-00
Genuine carbon fibre weave
- 5 speed markings on the top or without
Silver Carbon and Black Carbon
R570-00
Fitting kit included with all
- Stainless steel band and housing
- Ideal for high pressure applications
- 51mm
- 57mm
- 64mm
- 70mm
- 76mm
- 83mm
- 86mm
- 89mm
- 102mm
Between R40 - R55
- 12 volt radiator fan controller
- Fully programmable
- Cooling fan switch adjustable from 0 ~ 100°C
- Low voltage and overcharge warning
- Real time radiator temperature and voltage information
- Comes with all wiring and components
R1450-00
- Electric sender
- Large easy to read numerals with full sweep
- Red/Blue digital display
- Includes fitting kit
- All 52mm gauges
Air Fuel Gauge - R950-00
Oil Pressure Gauge - R950-00
Oil Temp Gauge - R950-00
Turbo Boost Gauge - R1750
Vacuum Gauge - R1750
Volt Meter Gauge - R950-00
Water Temp Gauge - R950-00
High quality anodized alloy
- Stops oil vapour re-circulating into intake
- Maintain life & efficiency of engine
- Stops blow by and catches excess oil
- Must have for turbo applications
- 600cc capacity
Black, Blue, Red and Polished avail
Hose Kits also avail
Exhaust Noise Control Valve 80mm
Varies loudness of exhaust volume
- Can reduce loudness by up to 10dB
- ‘On the fly’ adjustment with cockpit control
- Can be used for side exit exhaust and racing purpose
R1850-00
Black with Red light
Silver with Blue light
R560-00
Universal steering hub fitment.
All wheels are 350mm
Genuine Leather
Perforated leather for ultimate feel
Full Round or Slightly flat at bottom
R1100-00 for Yellow center point suede
R1450-00 for normal steering
Red, Blue, Gray or full Black avail
- Greater side impact protection
- Adjustable headrest
- Right & left lap & sash seat belts guides ensures the belt is fitted correctly for safety and comfort
Black
Red
Blue
Gray
R550-00
Braided Hose and Anodized fittings:
custom_motorsport@yahoo.co.za
