Hey guys
Does anybody have a 76mm holesaw that I can borrow in the JHB area?
I cant see the point to pay R250 for it only to use it once.
I need one to fit my intercooler.
It needs to be able to cut into steel.
I will really apreciate it if anybody can help me out on this.
I will return it. I just need to make 1 hole.
PM me if anyone can help
Thanks
76mm Holesaw
- VegetaSSJ4
- 0.2 Bar Boost
- Real Name: Philip Broodryk
76mm Holesaw
---------SKYLINE---------
(O O) - - R33 - - (O O)
----------FTW!!!!----------
- Skylinefreak
- 0.5 Bar Boost
Re: 76mm Holesaw
I used something like a 90 or 92mm holesaw to drill a hole for my 76mm boost pipe and then fitted a rubber lining in the hole.
- VegetaSSJ4
- 0.2 Bar Boost
Re: 76mm Holesaw
Do you know where I can get the rubber lining?
And somebody that is willing to lend a holesaw to me.
- Skylinefreak
- 0.5 Bar Boost
Re: 76mm Holesaw
I still have the holesaw here somewhere and some of the lining, there's a place near Eastrand Mall that sells it. Will look for the name and address and post it up. Otherwise go look in a scrapyard for an older Opel Kadett (Superboss shape) they have a rubber seal under the bonnet that works well.
- Skylinefreak
- 0.5 Bar Boost
Re: 76mm Holesaw
Pro Auto Rubber, corners of Romeo & Oscar street, Hughes ext 15, Boksburg
- Daniel
- Real Name: Daniël
Re: 76mm Holesaw
I got a rubber lining from Midas, it actually had a chrome strip on it but that was easy to peel off.
