Intake Interest
Intake Interest
http://www.nissansilvia.com/forums/inde ... um+install
I'm phoning around lets see how much I can get this done in SA for
Something like this you mean?
Which has stuff like this inside it
That is a general schematic of the plenum chamber which bolts onto the runners hence the Flange with all the holes.
By the way its not for a S anything its for another car but you get the idea
You really expect me to post everything with all the dimensions on a public forum?
Last edited by The Calibrator on Mon Jun 11, 2007 1:18 pm, edited 2 times in total.
Help confused.. .
Wheres the inlet and the runners?
Is this a top View? Side view?
More interesting stuff.. I didnt know they still made the SR20VET 206 Kw / 305 Nm Damn
Link: http://www.nissansilvia.com/forums/inde ... pic=237435
Nissan Link:
http://www.nissan.co.jp/X-TRAIL/T30/030 ... main1.html
Nissan Link:
1: Because if you angle them you have one side of the venturi close to the wall. This limits airflow on that side.
2: Bends are a restriction the more bends you have the bigger the restriction.
3: If you angle them all the same way then the 1st one will get plenty of air and the rest will be in the 1st ones "shadow"
4: Space constraints limit the size of what can be fitted in.
5: Machining costs
5: Machining costs
1. I meant angle them all to face the throttle body.Posted: Mon Jun 11, 2007 2:54 pm Post subject:
5: Machining costs
2. By having the runners at 90 degrees to the plumen the air is already changing direction so you cant loose much more than that.
3. The plumen should be shaped in such a way that the air is evenly distibuted. Look at a F1 air intake, its kinda triangle in shape, because the air will want to flow on the surface of the plumen the back cylinders would get more air than the front ones.
4. -
5. I think this is the biggest factor, if you told someone you can build the best air intake in the world but will cost you R12000 they would laugh at you. Just to design a decent air intake would a week or so and at R285.00/hour (or what ever you charge) is big bucks.
Its call a velocity stack, The above picture is a 2002 F1 car's intake system.Phinx wrote:
The Intake that Calibrator suggested is correct and would probably flow the best
But you forgot to add the picture of the air intake cavity, the F1 one is very intricate in design and uses the gas laws to aid in the flow into those cylinders. As I said they are "trianglular in shape to even disperse the air through out all the cylinders. They also have vents, ducts and channels to speed and aim the air going into the cylinders. I read somewhere that a F1 motor can as much as 0.5bar positive pressure at the inlet valve, yip that means boost from a NA motor.
The plumen Duane will make will probably be a hollow cavity so nothing aiding in the filling of the cylinders. But as I said I think cost in the major factor here.
I personal like the shape of the stock one, I think if you could take most of the metal away and seriously flow it you could get some good results. But then again I know nothing of our plumens, never had mine off.
But Duane's Will be shaped very similarly to control the path of the air.
It will tapper down to the end on the intake
If you angle them all to the throttle body you will get shrouding unless you have a huge plenum and point them all in different directions ala BMW M5 and the only reason the angle them is due to height constraints.1. I meant angle them all to face the throttle body.
4. -
The whole idea of a plenum is to have a reservoir of air that the motor draws from, not to direct the air down each runner. BMW's intake systems are among the best in the world and not one of them does as you suggest.
The reason the plenum is big in front and tapers is to allow the air to slow down immediately after the intake so that you dont get it bypassing the 1st runners.
I think you are referring to the 2nd drawing, the 2 venturis are misleading there are 4 but I have only shown the 2 outer ones.
They are actually welded to a flange which is bolted to ITB's the intake to the right is only a intake not a throttle body.
The plenums above are under construction. The ITb's are bolted onto a 2.2ltr SR20DE with equal length exh manifold and T3/T4 turbo. It also happens to have HKS cams and Greddy cam gears in a flowed head.
Pics on my website ( turbo sabre)
The F1 cars will have positive pressure due to the ram effect of air being forced into the plenum at high speed.
If you give me a F1 budget I will also make you a carbon fibre dream.
OEM intake manifolds are fairly well designed with the cars intended use in mind.
Its only when you start looking for every last hp that you would need to change it.
- Vlade
- * - Club Pimp - *
- Real Name: Barend
Ummm interesting stuff as the topic siaz...
On the CA18DET I can nearly confirm that the first cylinder doest get more air than the rest, how can I confirm this?
Well on all the import motors I the first intake chamber are always the dirtiest on mine and Ero's I had to manually clean them...
Also our plunems serve a duel purpose, its meant for FWD engines and RWD, on FWD engines the intake actually sits on the opposite end, one can actually swap the front and the back...
So the Nissan boys didn't design ours for performance but rather for re usability and cost saving... would be nice to see what performance increase you can get from just a decent designed plunem its like free power
Dirty intake runner normally meansWell on all the import motors I the first intake chamber are always the dirtiest on mine and Ero's I had to manually clean them...
Little airflow (leass than the others) Dirt settles where the air speed is lowest.
Reversion ie intake valves dont seal properly or cam overlap excessive at low rpm.
Engine breather directed to or near the runner in question.
in any engine the cleanest intake runner assuming a good condition engine will have the highest air flow.
Sorry
