S13 Rb25det Engine setup
Stock engine. Never been opened.
No turbo, clutch or flywheel. Think I still have auto flywheel. also have stock manis.
Work done:
Freddy intake
Oem thermostat
Greedy timing belt
Oem water pump
Offers?
Re: Rb25det engine forsale
mmm... pm me a price what you want for it please.
No clutch, box or flywheel. Perfect chance to get light flywheel and decent clutch something like ACT
Box i know someone selling a RB20 box for R1800.
R15000 Will get you: (adding what i paid for them)
(R10500)Motor - head block never opened
(R2900)Freedy intake mani
(R1500)RB26 Fuel rail and FPR will custom spacers can support 600hp
(R2500)440cc GTR topfeed injectors that were cleaned. Give you about 320hp.
(R1200)Greedy timing belt
(R2500)OEM water pump
(R250)Thermostat.
(R800)Heater Hoses.
(R500) CA18 CAS with dicktator disk
(R1500) Modded S13 Harness. What i was charged me to wire up.
(R1500)Engine mounts
(R1000)Modded prop for RB25 box
(R3500)Mount Brackets Engine and RB25 box
(R1200) Tacho coverter box
(R2500) 50mm ali radiator
(R500) Radiator Hoses
(R1000) 12" and 10" fans
R35000 will get you
All of the above
(R16500)GT3071R awesome turbo (500hp)
(R2900) Tial 38mm wastegate
(R3900) autobann88 exhaust manifold
(R1000) Custom turbo lines
(R4500) 76mm S/Smandril exhaust with flex pipe and 1 box.
Please Note engine needs new rings (oil) compression still in spec.
