For someone who is no technical ghuru, check out the following on the web. It is a piece of cake to change disk pads yourself. I posted the part numbers and prices.
http://www.garage411.com/BrakePadsS13
Cheers
S13 Change Brake Pads front and back
- Christiaan
Jeremy Clarkson
Jeremy Clarkson
Re: S13 Change Brake Pads front and back
Cool going to this in a month or 2
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
Can anyone tell me what is the part numbers for the front and rear discs? and maybe the sizes, because the front apparently has a 280mm or 258mm....
- Christiaan
The chap at Powerbrake told me that on the S13 the '94 models have a larger front disk. Towards the end of their run they made a change. I just took his word for it. I can measure the ones on my car if you do not come right somewhere else for you.Grobblere wrote:Can anyone tell me what is the part numbers for the front and rear discs? and maybe the sizes, because the front apparently has a 280mm or 258mm....
Groete
Jeremy Clarkson
Jeremy Clarkson
Our s13 .SA cars have 280mm disks. Pignose s13 had smaller disks
- rat
- Real Name: Rat
Our 91's had the 256mm disks rest had 280mm.
