gear lever loose s13
araf69
Post by araf69 »
Its on my 200sx s13 running ca18det gearbox. It doesn't affect gear change. Its just wobbly. Any recommendations to make it abit more stiff. Even if it in gear there is some play
NIZAN-R
Real Name: Renier
Re: gear lever loose s13
Post by NIZAN-R »
get a new bush for the shifter it will sort it
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
araf69
Post by araf69 »
Can't match 1 locally like citi golf bushes? And a DIY on this
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
you will have to remove it and try midas
or
diy make it from teflon
araf69
Post by araf69 »
Cool will pull it off and see
Reyn S
Post by Reyn S »
You can get at Nissan +-R50
araf69
Post by araf69 »
Got the bush today only from nissan. 25bux. Now to fit it. How long job it is. Basically what I need to DIY this?
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
Remove radio suround
10mm socket to remove rubber boot thing
internal circlip pliers to get shifter out
araf69
Post by araf69 »
Done, took me less than 1 hour. Got instructions from the fresh alloy forum. gear wobble is gone
