Z32 na speed sensor
antman
- Engine: VG
- Real Name: Tony
Re: Z32 na speed sensor
Hi Rat, I don't have what you need but I think you must specify manual or auto transmission as I know the speed sensors and plastic gears are different as I did an auto to manual conversion to my 300zx TT. If its rhe gear you are after get one from the US, takes about 3 weeks.
Cheers
Cheers
- rat
- Real Name: Rat
its for my RB25 S13. It would be the sensor and gear.
It seems the Z32 NA must be manual sorts the speedo out.
that will be the red gear (4.083 ratio)
get it here
http://www.z1motorsports.com/index.php?cPath=4_40_149
get it here
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
- Skylinefreak
- 0.5 Bar Boost
Nope he needs the 19 tooth white gear.
- èXederoN
- Real Name: John Hayes
I used my RB speed sensor...It was reading about half speed..
So at the back of the cluster on the rev counter and speedo(underneatch the electrical tracks)
there are two pots(adjustable resistors)..
So we took the cluster apart and started adjusting it..Cant remember to what side we turned it but now
it reads within 5kmh of the gps..
Same with the rev counter that was reading too fast..
2007 Audi A3 2.0TDI -Daily drive
1992 RB25SX
2011 Kawasaki KX 450 F
1995 2JZ-GTE Hilux 4x4
1992 RB25SX
- rat
- Real Name: Rat
sigh
ordered this morning from nissan a vg30 speedo drive and 19tooth gear
