Grobblere
0.6 Bar Boost
Posts: 681 Joined: Mon Jan 17, 2011 11:35 pm
Real Name: Eugene
Post
by Grobblere » Tue Feb 14, 2012 3:18 pm
Hi Guys
I need your help, does anyone know which rubbers also fits in the front stabelizer bars in the S13 suspension, mine is
. As you know the spare shops can help me but then i need to remove my bars for a sample....and im reeeaaallly not in the miid for that
The other option is to get a used one from someone and make a custom one or solid, so if someone has some used stabelizer bars id really appreciate it if i can borrow one for a sample
I am from centurion area
Regards Eugene
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post
by Grobblere » Tue Feb 14, 2012 5:07 pm
C' mon guys i need your help
Posts: 2991 Joined: Tue Aug 01, 2006 1:39 pm
Post
by Daniel » Tue Feb 14, 2012 5:17 pm
The drop links or the bushes?
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post
by Grobblere » Tue Feb 14, 2012 5:36 pm
Thanks Daniel
Here is the pic of the culprit
Post
by Daniel » Tue Feb 14, 2012 5:49 pm
Oh! I thought you were talking about the ARB.
A friend made a set of adjustable tension rods. I'll ask if he still has a set
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post
by Grobblere » Tue Feb 14, 2012 6:25 pm
Awsome, thank you very much Daniel
White Fang
Posts: 1330 Joined: Wed May 18, 2011 7:16 pm
Real Name: Qubitt (Qbit)
Post
by White Fang » Wed Feb 15, 2012 7:17 pm
o hell !
Daai is kak , om te replace , Chriss hier op die forum het n complere set ,
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post
by Grobblere » Wed Feb 15, 2012 10:45 pm
Haha, ja nee ek sien nie uit daarna nie. As ek net n sample kan kry dan kan ek self solids laat maak of iets van n ander materiaal laat draai.
Daniel het jy dalk al iets gehoor by jou vriend? Sal dit baie waardeur
Christiaan
Posts: 94 Joined: Tue Apr 27, 2010 5:33 pm
Post
by Christiaan » Sat Mar 03, 2012 5:07 pm
PM sent
Jeremy Clarkson
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post
by Grobblere » Sun Mar 04, 2012 9:42 pm
Shot! Will give you a shouT
Post
by Daniel » Mon Mar 05, 2012 7:40 pm
Sack I'm sorry, I forgot about this.
If your still struggling phone my mate zero76 976 2zero59, ask for Riaan.
I told him what you wanted and he said he could cut new bushes for you for R600 (tbf, im not sure if he had the right part in mind as he thought there are four bushes and I thing theres only two)
Also he can make a set of adjustable arms.
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post
by Grobblere » Mon Mar 05, 2012 8:55 pm
Hi Daniel
No prob, im going to phone Christiaan throug the week and get the sample, maybe just take to your but and see what he can do and at what price. I know Christiaan is looking for some adjustable rods
White Fang
Post
by White Fang » Mon Mar 05, 2012 9:43 pm
Julle wheel en DEAL te veel !
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post
by Grobblere » Mon Mar 05, 2012 10:25 pm
Haha,
ek kan nie help om te wheel en deal nie!, ons maak altyd n plan en nou kan ons die ander ouens ook help met die goed
Miskien moet die ander mense wat ook die goed wil he inspring en saam koop
White Fang
Post
by White Fang » Tue Mar 06, 2012 7:38 am
BWHAHAHAHHAHAAHAHA !
Die maak is nie die probleem nie , Dit is die insit !
Julle moet julle huiswerk mooi doen ,dan kan almal hier uit baat !
Moer ek verduidelik ? Of het jy n idea ?
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
