Loose Rocker
- k.y.l.e.
- Real Name: kyle
Loose Rocker
Hey guys was driving on the road in 2nd gear put my foot down and changed to 3rd and as i released the clutch all i heard was grrrr loud, a budi helpd me take off the tappet cover and saw the rocker came loose didnt realy damage the cam but bent a valve,is there any thing i can add to the rocker to prevent it from jumping loose again, heard you get somthing you ad to your rocker.
Any help would be much appreciated thanks.
NIZAN-R
- Real Name: Renier
Re: Loose Rocker
tomei/greddy/hks rocker arm stoppers
- k.y.l.e.
- Real Name: kyle
Re: Loose Rocker
Thanks nizanR, how much do they go for each, its for a s14 sr20
NIZAN-R
- Real Name: Renier
Re: Loose Rocker
most retail $100 tomei greddy
cheapies
http://www.ebay.com.au/itm/GKTECH-S13-S ... 3cba481b4d
tomei
http://www.ebay.com.au/itm/TOMEI-ROCKER ... 2312fe07c7
trust/greddy
http://www.ebay.com.au/itm/TRUST-ROCKER ... 4157eae325
HKS
http://www.ebay.com.au/itm/HKS-Rocker-A ... 2a18dc9a4a
cheapies
tomei
trust/greddy
HKS
- k.y.l.e.
- Real Name: kyle
Re: Loose Rocker
Thanks nizanR much appreciated budi.
- k.y.l.e.
- Real Name: kyle
Re: Loose Rocker
Hey guy's did a little research and they saying rocker stopers is bad as it prevents the cheap things from braking and causes bigger things to brake how true is this? And my valve bent when my rocker jumped off is there no other way to prevent this from happening?
- aep886
- Real Name: Davey
Re: Loose Rocker
RAS does good only... as far as i know... if you want to rev your engine it a must!
current vehicles...
1979 Corolla SR5
1996 S14 200sx
1979 Corolla SR5
1996 S14 200sx
- mario_200sx
Re: Loose Rocker
Rocker Arm stoppers is a good idea. Especially as you running uprated cams. Perhaps you should look at improving your vavle springs as you are running a bigger cam than stock.
What is your rev limit set at?
- k.y.l.e.
- Real Name: kyle
Re: Loose Rocker
7000rpm or 7500rpm not to sure now but last time i took note is 7000rpm, thinking of getting a good set of valve springs and valve retainers
- White Fang
- Real Name: Qubitt (Qbit)
Re: Loose Rocker
solid lifters !
problem solved , or as 100000 rpm rev kit
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
- k.y.l.e.
- Real Name: kyle
Re: Loose Rocker
Hey whitefang could you give a quik run down and a discription on that solid liftes as im not too clued up about that?
- White Fang
Re: Loose Rocker
LOL ................... dis kak duur conversion , mar moer sterk ,
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
- mario_200sx
Re: Loose Rocker
Dont bother with solid lifters. Upgraded springs and retainers is the answer.
- phoenix s14
- Real Name: Mark Appelgryn
Re: Loose Rocker
Well the problem with just going with stiffer springs etc is that it puts even more stress on the lifters. I would go solid lifter but you looking at about a R5000 conversion. Springs and retainers are cheaper and I would do those also. problem is the amount this all ads up to. However it is worth it for a bullet proof head setup. Note though that you will still need rocker stoppers.
- k.y.l.e.
- Real Name: kyle
Re: Loose Rocker
Hey Phoenix s14 that mod sounds like the head will be bullet proof but very very pricey just the valve springs and retainers alone R2899, wish i had the cash.
