some of you might already know my project which i introduced in my project thread here.
However due to high tuition fees of my next university i have to sell the car to finance my further studies.
I'm from Germany but I sell the parts worldwide, hence shipping to SA ain't a problem.
Nearly all parts are brand new, that means that they were test fitted but the engine was never started and the car never saw the road/track.
However I will mention if a part is used and will describe its condition.
Most of the parts will fit the S14 & S15 also, I will mark S13-exclusive parts with [S13].
Parts of these manufacturers are/were for sale: 5Zigen Apexi ARC Blitz Cusco Defi Exedy Greddy HKS Ikeya Formula JUN Kaaz
Koyo Nismo ORC OS Giken Project Mu Tanabe Tein Tomei ACT ARP CP Garrett JE Pauter TIAL Walbro Wiseco
Shipping costs to South Africa are included in these prices:
[ Fueling ]
6x Bosch Injectors 440cc (480cc 550cc 600cc) Top Feed, EV 6 CS incl. Plug . Price ZAR 5200,00 (As a combo with the manifold conversion = ZAR 14600.00!)
These injectors are brand new and fully functional and are originally beeing used by Porsche in the GT3. Original price was ~700,00 EUR, Bosch part number 0280156012,
high impedance 12 Ohm, max. 8 bar fuel pressure, can be used on 6 bar pressure all day long, the performance depends on the fuel pressure:
453cc @ 43.5 psi/3 Bar (standard-pressure), max. ~400hp,
480cc @ 49 psi/3.4 Bar, max. ~450hp,
555cc @ 65 psi/4.5 Bar, max. ~500hp,
600cc @ 76 psi/5.2 Bar max. ~550hp,
640cc @ 87 psi/6 Bar, max. ~600hp
RB20DET & RB25DET NEO - plug & play
RB25DET - you will need a Greddy/Freddy Inlet Manifold + top feed rail + use included plugs
RB26DETT - you have to remove/bypass the small resistor pack see here
Datasheet downloadable here, a good FPR is for example the "FSE Motorsport 6 Bar",
every good mapper can work with these injectors, same performance and quality as Nismo injectors but much cheaper.
[Cooling]
Oil Pickup (RB25DET) Price 150,00 ZAR
Delta-R exhaust gas temperature sensor (EGT Sensor) TS-200 + fitting Price 500,00 ZAR
brand new sensor
