Throttle position switch-9MM shaft !
I want to fit a tps to my car. The TB on it at the moment has the "d" type shaft but it`s a damn 9mm diameter shaft !
All my tps`s are all 8mm "D" type units. Now, is it just the chinese t/b/ or did I miss something and there is a 9mm shaft t/b around.
If so, can someone point me in the right direction here please..
Otherwise it modification time again...
Re: Throttle position switch-9MM shaft !
Got a std RB25 TB with TPS on it, can send it up with nate or bg if you need
Shot bud, please do. We will sort the finances out for it tomorrow when Im at the shop..
